20 Most Recent
Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet Questions & Answers
Need winding key & instructions for seth
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Have a Seth Thomas Banjo clock - estimated to be @
Is it spring wound or weighted with pine cones? I have a feeling the movers wound it up for you and over wound it. you can release the tension on the spring by carefully letting the key unwind while you hang on to the catch, I just got a clock from somebody, it was way over wound, took about 10 full turns out of it and got it running, it has been going for about a week without touching the spring. I haven't got the chimes back yet.,,, Now if it is a weighted mechanism, the chain may have jumped the track. Check that out. Other than that, I can't see why it shouldn't work. Hope this helps.
Toilet keep losing water
You need to have your rubber flapper and/or valve replaced. OR...It's possible yours is getting hungup on something and not seating in place after flushing...check to make sure that's not the issue.
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
