20 Most Recent
Philips 47PFL7403D 47 in. LCD TV Questions & Answers
My Philips Tv Model #47PFL7403D/27
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/30/2017 2:05:06 PM •
Philips...
Answered
on Apr 30, 2017
Philips flat screen tv
Board for the screen has a bad component or a bad solder joint. It will need to go to a repair shop. It may be cheaper to replace the tv.
7/4/2016 3:38:20 AM •
Philips...
Answered
on Jul 04, 2016
Need to take the back off of the set
In addition to all the screws around the edge there are three screws on the input panel, one on the side and two black screws among the AV3 inputs. One screw by the power plug.
7/25/2015 4:52:06 PM •
Philips...
Answered
on Jul 25, 2015
My tv just turns off
Fault to the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
8/1/2014 2:06:39 PM •
Philips...
Answered
on Aug 01, 2014
Inverter board blew out
This is a common problem for this kind of TV.
You just put in a new PCB master and slave board.
Or use a repair-kit and replace the defected parts on the board.
INVERTER BOARD NUMBERS REPAIR KIT NUMBER
Master - 6632L-0470A PNEL-T707A KIT63
Slave - 6632L-0471A PNEL-T708A KIT63
As used on the LG / PHILIPS LCD PANEL TYPE: LC420WU5
Examples of models that use this panel:
• PHILIPS 42PFL7662
• PHILIPS 42PFL9900D10
• PHILIPS 42PFL5332D
• PHILIPS 42PFL7332D37
• PHILIPS42MF337B/37
4/4/2014 8:03:24 PM •
Philips...
Answered
on Apr 04, 2014
Picture gets dark and shakes
Something overloads the secondary power supply voltage. A sharp troubleshooting should be done to your TV. Contact any
experienced service technician.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/24/2014 5:53:33 PM •
Philips...
Answered
on Mar 24, 2014
