20 Most Recent
LG WM1814CW Front Load Washer Questions & Answers
LE code on lg washmachine
The LE error code means that you have a motor problem. The high pitched noise means that the motor sensor has failed and needs to be replaced. You will need to call a qualified LG technician to replace the sensor.
Wm1814cw LG front load washer won't engage drain pump
Washer will not drain: The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure to check the pump to be sure a small object like clothing or similar has not lodged itself inside of it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Read more: HYPERLINK "http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/" l "ixzz3X2LbXMWJ" http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machine drain hose is where the water flows through to get the water out. If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the water from the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it The water pump belt (to drain out the water) may have broke or become frayed or loose. If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing the NO DRAIN issue and remove and replace if needed. If the lid switch is not working as required it will cause your washer to not drain (and many other problems). This may be unlikely as a bad lid switch will usually cause your washer to also not agitate or spin. However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity My advice is free cuz God is good!
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Just Shuts Off
please call a local engineer as we don't know what type of machine your telling us about eric
Our LG Tromm WM1814CW frontload
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
What do I put in the machine for the tub clean cycle?
john low temperatures washing can cause the machine to smell
if it was me i would set the machine to it's hottest wash and use a descaller or bleach and washing liquid ,after wash has finished give it an extra rince cycle./ scrum around rubber seal behind door before starting wash. check pump filter is clean,
When draining the machine makes noise
If there is a back panel on the machine you can access it from there, if it has a enclosed back then you will have to lean the machine backwards against the wall to get underneath to access it. The pump has two wires attached to it make sure the power is off & lead removed from wall before you unplug them otherwise you get zapped. The drain pump is held into the pump casing/housing by three Phillips head screws. Undo the screws remove old pump and replace with new pump, make sure rubber seal is on the new pump before installing. You will need a torch & a Phillips head screw driver.
