20 Most Recent LG WM-1832C Front Load Washer Questions & Answers
2answers
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG. you must transform the 60hz to 50hz or 50hz TO 60hz.God bless you
1/8/2024 1:16:57 AM • LG WM-1832C... • Answered on Jan 08, 2024
3answers
Start/pause button doesn't work
I had this problem with another model LG washer dryer and the problem was just the tiny switch (6mm x 6mm) on the circuit board had worn out. They cost about 30 pence on eBay and are very easy to remove and re-solder onto the circuit board as there are only 2 pins. This saved a huge amount of money for a new control board.
10/23/2019 2:18:52 PM • LG WM-1832C... • Answered on Oct 23, 2019
2answers
LG WM-1832 Awful noise - Spider in broken - How to fix ?
Seems like you need beaucoup parts and with what they charge for parts you just might be better off getting a new machine. If you go to the attached link you can find out the part numbers and prices of the parts you want - if you ask them your question they will have the answer for you right there. http://www.appliancepartspros.com
3/24/2017 4:37:41 AM • LG WM-1832C... • Answered on Mar 24, 2017
LG Washer not completing spin cycle and says LE
It is either: 1. Thermistor error. $6 part. Easy repair 2. Motor position sensor issue. $18 part. Easy repair check out repairclinic.com or appliancepartspros.com for repair videos. Thermistor can be replaced from bottom of washer . Videos show you where it is.
3/10/2017 5:35:48 AM • LG WM-1832C... • Answered on Mar 10, 2017
Wm1832cw le error code
le is bad hall sensor
2/23/2017 10:16:23 PM • LG WM-1832C... • Answered on Feb 23, 2017
2answers
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
6/18/2015 8:11:16 AM • LG WM-1832C... • Answered on Jun 18, 2015
Washing machine will not stop filling during rinse cycle resulting in an FE error
Washer fills with water and overflows: The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective. You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED). The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test. Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed By the way my advice is free cuz God is good! 13995450-0ibogqi43422e0jrk2ickvgv-2-0.jpg 13995450-0ibogqi43422e0jrk2ickvgv-2-2.jpg 13995450-0ibogqi43422e0jrk2ickvgv-2-5.jpg 13995450-0ibogqi43422e0jrk2ickvgv-2-9.jpg 13995450-0ibogqi43422e0jrk2ickvgv-2-14.jpg 13995450-0ibogqi43422e0jrk2ickvgv-2-20.gif
5/25/2015 11:56:35 PM • LG WM-1832C... • Answered on May 25, 2015
Dial spins but wont swith from normal cycle to other cycles (IE delicate, heavy, etc)
ur timer teeth are most likely broken 16787644-0ibogqi43422e0jrk2ickvgv-2-0.jpg 16787644-0ibogqi43422e0jrk2ickvgv-2-2.jpg 16787644-0ibogqi43422e0jrk2ickvgv-2-5.jpg 16787644-0ibogqi43422e0jrk2ickvgv-2-9.jpg
5/25/2015 9:48:21 PM • LG WM-1832C... • Answered on May 25, 2015
Washer won't drain or spin
Washer will not drain: Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement. Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed. If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good! No spin, or lite spin try these: Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically. Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage. next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN By the way my advice is free cuz God is good! 22755575-jkb5ybrklduaa4afh4xyzipe-4-0.jpg 22755575-jkb5ybrklduaa4afh4xyzipe-4-2.jpg 22755575-jkb5ybrklduaa4afh4xyzipe-4-5.jpg 22755575-jkb5ybrklduaa4afh4xyzipe-4-9.jpg 22755575-jkb5ybrklduaa4afh4xyzipe-4-14.jpg
5/25/2015 6:59:47 PM • LG WM-1832C... • Answered on May 25, 2015
5answers
Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
4/30/2015 12:37:37 PM • LG WM-1832C... • Answered on Apr 30, 2015
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE; LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it. THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS, THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
3/30/2015 7:52:28 AM • LG WM-1832C... • Answered on Mar 30, 2015
Drum cannot turn clothes around with water in the machine
Could be a lot of different things. In the one time I had this experience it was a hot pad (that's made like a coil). It had slipped through between the drum (that spins the cloths) and the tub (that holds the water). It traveled to the rear of the machine, unraveled, and got wrapped around the axle in the back inhibiting movement. I had no idea that's what the problem was until I took apart the machine - which included removing the entire tub and drum from the body of the washer and opening it up - removing the clips that hold the two halves of the tub together around the drum. This also involved removing the weights from the tub and drum. It's a very time consuming process. Hopefully you only have something like a broken belt. That would be easier to repair.
3/17/2015 5:51:25 PM • LG WM-1832C... • Answered on Mar 17, 2015
WHY DOESN'T MY LG WD-80259NP PUMP WATER OUT
check for pump blockage or replace
2/23/2015 10:44:41 PM • LG WM-1832C... • Answered on Feb 23, 2015
2answers
Lg washer 1832c now power from switch to start but has power to the circit board
Hello Jerry; My name is Peter. I am a retired field service appliance technician. If you do not have lights on your display, then I am afraid it is your main control board. You have a old unit and the control board is no longer available through Sears. You can purchase it through Amazon for $94.00. Part Number 6871EC2025E. If you elect to replace the board you will receive it in a silver anti-static bag. Before touching the board; GROUND YOURSELF BY TOUCHING BARE METAL WITH YOUR HANDS. STATIC ELECTRICITY WILL KNOCK OUT THE BOARD. You may want to purchase the board, go into the Sears Home Services website, print out a 10% Off Service coupon, and call sears to schedule a service call. Rule of Thumb: "If the repair cost is 1/3 or more than the original purchase price, then buy new". If your display lights are on, then: 1.) Bad Door Latch - Your unit will not run if the control does not get a signal that the door is closed. 25396209-azn3vdefrt5enyqdbzatir1e-4-0.jpg Part #: 6601ER1004C Cost: $52.00 2.) Bad Drum Rotation Sensor - This will shut your unit down. 25396209-azn3vdefrt5enyqdbzatir1e-4-2.jpg
2/3/2015 1:42:03 AM • LG WM-1832C... • Answered on Feb 03, 2015
How do I reset lg waher 1842cw it started stopped and now wont start
waher 1842cw? Have you looked at the trouble shooting measures in your manual yet? Check that first.
2/2/2015 8:23:17 PM • LG WM-1832C... • Answered on Feb 02, 2015
The drum doesn't want to vibrate
If the washer won't agitate or spin, then the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
11/28/2014 12:43:34 PM • LG WM-1832C... • Answered on Nov 28, 2014
LG WM-1832C Front Load Washer Logo
321 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
water inlet error
  • Washing Machines
