20 Most Recent Makita 10" Miter Saw LS1030N Questions & Answers
2answers
I have a Makita LS1013 Dual Slide Compound 10-inch Miter Saw. It was working one minute and next no power!
How did you measure the power at the switch Live to N ? that would rule out a break in the cable all that is left is Armature ,Stator coil and wiring to both.
6/2/2022 3:59:02 PM • Makita 10" Miter... • Answered on Jun 02, 2022
How to replace saw blade and re assemble the blade
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
5/5/2021 9:04:36 PM • Makita 10" Miter... • Answered on May 05, 2021
Makita LS1221, started heavy sparking
you need to make sure the brushes move freely in the tubes and if they do I would suspect the armature is bad. LOOK for discoloration in the commutator thru the brush tubes.
3/28/2018 6:53:48 AM • Makita 10" Miter... • Answered on Mar 28, 2018
2answers
How to reassemble helical gear onto spindle with woodruff key
You need an arbor press to do that. If you have an auto mechanic you normally use they should have one and would probably be glad to do it for you.
3/13/2015 7:44:15 PM • Makita 10" Miter... • Answered on Mar 13, 2015
Why doesn't the laser marker work on my Makita mitre saw?
contact Makita, it may be defective , or they can troubleshoot. You can check on youtube.com for a possible fix also.
3/7/2015 12:24:02 PM • Makita 10" Miter... • Answered on Mar 07, 2015
Makita LS1030 (not LS1030N) won't turn.
Turn it over , there is a 1/2 moon type metal ring called a "slide plate" that is holding it to the base. It is part #94. Here is a link to a pdf http://www.toolpartspro.com/image/LS1030/LS1030-Makita-PB.pdf Hope that helps & good luck. Don
1/15/2015 5:57:34 PM • Makita 10" Miter... • Answered on Jan 15, 2015
Makita LS1030 miter saw, base doesn't rotate as
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
1/13/2015 1:07:14 AM • Makita 10" Miter... • Answered on Jan 13, 2015
Makita miter saw wontr turn on
make sure that your outlet is hot, once verfied that you have power going to the plug of the saw cord, verify that you dont have any breaks in the cord itself. once verified no issues with cord you can check for power at the switch, if there is power at the switch but not coming on, probably bad switch. If you need further help, reach me via phone at https://www.6ya.com/expert/allen_b068623c5003aa4b
11/6/2014 4:21:11 AM • Makita 10" Miter... • Answered on Nov 06, 2014
The cutting disc on my makita 5806b spins anti clockwise causing damage if i cut laminate from the top and i need it to spin clockwise
You could turn the laminate over. The proper tools would be either a router with an edge bit ( what I and most cabinet makers use ) or a low tech utility knife (carpet knife ) yep just a razor knife - really it works. Don
6/13/2014 7:43:20 AM • Makita 10" Miter... • Answered on Jun 13, 2014
Makita 10" Miter Saw LS1030N Logo
124 questions posted
Top Makita Saws Experts
Sean Wright
Sean Wright
john h
Are you a Makita Saw Expert? Answer questions, earn points and help others
View Most Popular
Makita Saws
  • Makita Saws
Most Popular Question
replace saw blade re assemble blade
  • Saws
