20 Most Recent
Black & Decker SZ360 Cordless Power Scissors Questions & Answers
How to replace battery on black & decker SZ360
I found a 1200mah 3.6v NiCd pack at BatterySpace.com for $10.99 each, the lowest shipping cost was FedEx Ground at $13.04 so I bought three of them, I'm sure I know some others that will need the other two. The quote 5 days to ship, in case they need to assemble them from individual cells.
The only issue is that I probably will have to modify the tabs to match the wiring in the scissors body, I'm sure Mr Dremel will come through for me on this point.
Black and Decker is most certainly *not* the best place to look, they have an exploded-view diagram of the scissors but have discontinued all parts for this model.
Van
How to reset password
Go to Yahoo.com and type in the manual you are looking for. it will tell you how to reset pasword
No replacement 7.2 battery pack.
It is possible to repack the battery yourself , just take the battery apart and inside you will find a set of rechargeable batteries , just replace the batteries with new rechargeables from battery world and repack them as original then put back together and hey presto NEW DRILL ,
Won't work
Most likely the battery is no good just from sitting uncharged, Ni-Cads do this, once flat they don't want to charge, test the battery voltage with a volt meter to verify this.
The blade on my black and decker radial arm saw is locked up. It will not move even by hand.
moved you out of cars to tools
well some have brakes, so hands not cut off, as it spins down.
what is the job here. not told what ACT is being attemped
or if you lost the manual that covers all this.
some blade bolts are LHT , left hand treading so , learn that first
if doing blade swaps.
buy this used and need to learn how to use it?
NO MODEL SAW TOLD at all, nor country told, some are different outside our USA< so not told.
is this the blade spin locked up, NOT TOLD
add more words or tell what your are attempting/
I guessed blade but gee I do no know what's up here
My Black & Decker electric weed-eater only
The bush/bearing behind the trimmer head is probably rusted or worn out and the motor is poling out and creating a short situation. Not much can be done so it may be best to junk it and get a new one.
Want to register a new
get the warranty card out of the box or from the back of the user hand book and fill out all the relevant details and post if off to the manufacturer. Or you may be able to down load from the manufacturers web site a pdf form for the registration.
