20 Most Recent
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Questions & Answers
How to replace belt on self propelled front gear drive craftsman 6.25
If it like mine take the cover off on the left rear you will see the belt it also has a cover on the bottom take it off you may be able fo use a screwdriver and froce the belt off if not pull the spring off the outer pulley remove belt and replace it with the new belt replace spring good to go.
What adjustments stop a self-propelled mower running....
the ignition coil is not grounding out the brake has a grounding wire it is probably not touching to ground it out but if you are in a hurry get a on off switch ground it to the frame hook the other end to the coil it works
MOWER WILL NOT RUN AT FULL POWER .
try empting the feul tank and put fresh feul in with a little dry gas treatment if that dont work try getting some carb cleaner in a spray can start mower and gingerly spay into carb trying not to over flood it keep spraying untill running smooth change CRANKCASE OIL and AIR FILTER.
Yard Man Gas Tank Leaking
replace the tank if you patch it and it fails when the engine is hot a fire is not worth what your trying to save try sears parts online to price it out
My lawn mower starts, then stalls immediately.
the carb will need to be removed and cleaned and blown out or ultrasonic cleaned is best if you can get that done? if not a can of carb or brake cleaner and blow through all the jets the blow out with compressed air
Yardworks problems
CHECK FOR METAL THAT IS STICKING OUT ON THE PULLY WHEN YOU FIND IT, YOU'LL HAVE TO SAND IT OFF OR USE A SANDER OF SOME SORTS TO GET IT SMOOTH AGAIN!!
