20 Most Recent Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Questions & Answers
2answers
My chipper shredder 5HP model 135212 type 027301 needs a new blade, where can I purchase one?
you've found the right place buddy I keep buying manuals from various websites so I can damn well help u in this.. what chipper is it btw? Like few websites have some manuals better while some have other brands better
10/6/2022 7:34:23 PM • Yard Machines... • Answered on Oct 06, 2022
I need to replace motor on MTD chipper/shredder.
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
1/23/2019 9:08:18 AM • Yard Machines... • Answered on Jan 23, 2019
Yard machine chipper/shredder won't start
my chipper had problem with wiring issue that the battery isn't able to take up the electricity supplied to it.. u know, the conductor between them.. if possible get a manual from reliable-store to fix it urself thats I did
1/22/2019 10:04:10 AM • Yard Machines... • Answered on Jan 22, 2019
Need to pull the impeller assembly from a Craftsman 247-776360
Some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try most shredder owners know about it it's free so no harm in trying
1/21/2019 9:52:06 AM • Yard Machines... • Answered on Jan 21, 2019
Problem with Yard Machines 120312 0158 E1 5.5 Hp
there's are website that I know all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
1/18/2019 11:41:16 AM • Yard Machines... • Answered on Jan 18, 2019
Chipper will not stay running . Needs continuous priming. won't chip
you can get guides online for error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered within seconds u can get the access and it's totally illustrative complete I know these websites
1/18/2019 11:20:28 AM • Yard Machines... • Answered on Jan 18, 2019
Hard to pull starter rope
I take help from online websites that have this service like helping in repair some have instant help.. others are a bit slow which I don't prefer... rest is up to us.. U can also get free manuals
1/18/2019 11:12:34 AM • Yard Machines... • Answered on Jan 18, 2019
How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
5/2/2014 7:30:19 AM • Yard Machines... • Answered on May 02, 2014
Need spark plug type and gap setting Craftsman 247.775870
Champion N4C, Gap: .030 Air filter: tecumseh 36046 Pre-filter: Tecumseh 36634
4/11/2014 12:57:00 PM • Yard Machines... • Answered on Apr 11, 2014
Balde wheel is engaged while
No. The blade is like a flywheel and is connected directly on the motor shaft. However, these usually have separate choke and throttle handles. I have found that they start easiest if the throttle is set pretty low and the choke is closed. Once it starts to fire, then slowly open the choke - allowing it to pick up a bit of speed before you open the choke all of the way. Then wait a few seconds before turning up the throttle. On the other hand, if you have debris in the machine making it hard to turn, you will have to clean some of it out before you start it. Good luck, Al K
5/22/2011 7:00:22 PM • Yard Machines... • Answered on May 22, 2011
I need parts for my
Here is a place that has parts listed for your model chipper/shredder.
http://www.partstree.com/parts/?lc=mtd&mn=24A-452G729+%282007%29
12/13/2010 12:57:20 AM • Yard Machines... • Answered on Dec 13, 2010
I would like to know
Hi, you can download the operator PDF manual for your chipper at this LINK. Type your model number like this ( 247.795940 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer where you can eithewr save it or print it out or both...
10/17/2010 9:10:40 PM • Yard Machines... • Answered on Oct 17, 2010
3answers
Yardman Chipper/Shredder won't run
I had this same problem after letting the machine sit for a couple of years with gas in it. What finally solved it for me was taking the screw out of the bottom of the carburetor bowl and cleaning it. I mean clean it. Carburetor cleaner or some other solvent helps but you've got to get the gunk out of that screw. It probably has an obvious "feed" that runs across the bottom part of the screw shaft. The "feed" that runs from this up to the carb is the tricky part. I needed something very fine and finally settled on a combination of strands of wire from a lamp cord. Try two or three strands twisted together and work it up and down with some carburetor cleaner.
9/13/2010 10:07:32 PM • Yard Machines... • Answered on Sep 13, 2010
5 HP B&S RUNS AT IDLE BUT WHEN ADVANCED TO FUL...
It could be the linkage, but the most likely problem is the throttle has gummed up in the idle position. Put thin oil or spray carburetor cleaner on throttle and move it back and forth to work it loose. I've seen it many times after an engine sits for awhile.
9/9/2010 5:46:53 AM • Yard Machines... • Answered on Sep 09, 2010
Can't pull starter, the cord is stuck.
I have the same problem. Did you get any help?
8/1/2010 3:20:50 AM • Yard Machines... • Answered on Aug 01, 2010
2answers
Need owners manual for 2001 yard machine chipper
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. ([email protected])
8/1/2010 3:19:57 AM • Yard Machines... • Answered on Aug 01, 2010
Will not start. It is 3 years old and has not been
You need to go over this machine thoroughly, disassemble carb and give it a full cleaning. Remove gas tank and clean thoroughly. Replace plug, change oil, new air filter the works! It should be fine after a little TLC, Good Luck and have fun!
6/8/2010 10:58:22 PM • Yard Machines... • Answered on Jun 08, 2010
2answers
I want to change the oil on my Yard Machines snow
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
4/6/2010 11:36:35 PM • Yard Machines... • Answered on Apr 06, 2010
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
1/23/2010 4:58:38 PM • Yard Machines... • Answered on Jan 23, 2010
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
36 questions posted
Top Yard Machines Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Heavy Machinery
Most Popular Question
replace flails 5 5 yard machine
  • Heavy Machinery
