20 Most Recent Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Questions & Answers
ELECTRIC blower will not start.
There may be a shorted winding in the motor. Bypassing the breaker may smoke the whole thing. Look in your phone book or online to find a Toro repair facility. They'll have any parts you need
9/12/2017 4:06:23 AM • Toro Blowers... • Answered on Sep 12, 2017
Blower does not start takes forever to start if it does atall
try starting fluid a few times. chekc spark filter etc
4/3/2017 5:51:22 AM • Toro Blowers... • Answered on Apr 03, 2017
Electrical burning smell
I had one like this. The problem is probably something wrapped around the blower. You may have injested anything from string to a piece of plastic.
8/3/2016 11:18:07 AM • Toro Blowers... • Answered on Aug 03, 2016
How do you convert the toro 51575 blower to a vac
nice post//
8/3/2016 10:32:42 AM • Toro Blowers... • Answered on Aug 03, 2016
2answers
How to change spake plug on powerlite snow blower
Remove the two screws holding the control panel to the machine. The spark plug is behind the panel.
3/8/2015 11:07:20 PM • Toro Blowers... • Answered on Mar 08, 2015
2answers
Where can I find brushes
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature! Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own. There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums) Search E-bay for: "Toro Blower Carbon Brush" - 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609). - 10.5 Amp leaf blowers Toro Old through Toro New model 51573. - 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
11/9/2014 5:31:36 PM • Toro Blowers... • Answered on Nov 09, 2014
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature! There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums) Search E-bay for: "Toro Blower Carbon Brush" - 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609). - 10.5 Amp leaf blowers Toro Old through Toro New model 51573. - 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
7/25/2014 1:25:03 AM • Toro Blowers... • Answered on Jul 25, 2014
3answers
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
4/16/2014 6:03:09 PM • Toro Blowers... • Answered on Apr 16, 2014
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
12/11/2013 4:02:30 PM • Toro Blowers... • Answered on Dec 11, 2013
2answers
Toro 521 snowblower..nn replace gas line to carb,
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
12/6/2013 11:12:32 PM • Toro Blowers... • Answered on Dec 06, 2013
2answers
Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
7/16/2013 8:24:29 PM • Toro Blowers... • Answered on Jul 16, 2013
4answers
Toro 51591 and torro 51599 will not start
try some starting fluid and change the gas
6/13/2013 4:55:55 PM • Toro Blowers... • Answered on Jun 13, 2013
2answers
Carbon brush for blower toro
I had a broken brush for an electic weed eater. I could not replace just the brush. I would have been required to purchase the whole electric motor. I chose to get rid of it, it just was not worth it. I suppose you may try to find a parts one, good luck. Or maybe see if you can get access to a carbon brush kit like the ones used for industrial maintenance. That may be your best shot, depending on who you know. Otherwise you will probably have to replace it. Sorry.
If really helpful, please rate.
5/15/2013 12:13:18 AM • Toro Blowers... • Answered on May 15, 2013
Won't turn on
Some of these have a reset button in a tiny hole in the bottom rear of the unit. Try pressing the reset with a hair pin or a paper clip. then try turning it on again. Hope it works for you.
12/9/2012 4:38:23 AM • Toro Blowers... • Answered on Dec 09, 2012
Would a broken blade on the impeller cause the motor to becomeexceptionaly loud?
You probably bought a new one by now.Nov. 2011. If the broken chunk was sucked into the motor? Yeah.
11/26/2012 4:27:44 AM • Toro Blowers... • Answered on Nov 26, 2012
2answers
Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut. I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
9/18/2012 1:40:21 PM • Toro Blowers... • Answered on Sep 18, 2012
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
125 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
find brushes
  • Garden
