20 Most Recent Toro Lawn Mower With Toro Power Tools Questions & Answers
My Toro 20332 started to squeal at the end of last season when I engaged the self-propel. I replaced the drive belt last week, thinking it was loose and worn, now it really squeals. Any thoughts?
The belt is slipping and that causes the squeal. If it squeals with a new belt, it is indicative that something is not turning freely, causing the belt to slip.
10/2/2023 6:56:09 PM • Toro Lawn Mower... • Answered on Oct 02, 2023
2answers
Have a toro LX425 steering
Does the sector gear turn when you turn the wheel?
Does the steering shaft fit tight in the bushing and does the bushing fit tight in the housing?
The middle of the pinion should be in line with the sector gear. Is this how it is? Did you have the the steering wheel off and check the splines in the wheel? Is the pinion gear turning?
Let me know,so that we could proceed further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
8/16/2021 11:30:42 PM • Toro Lawn Mower... • Answered on Aug 16, 2021
Left front wheel keeps falling
I have a 22" Toro Recycler Lawn Mower with front wheel drive. After many years the original tires wore out, primarily the left front. After I replaced the wheels the front wheels kept falling off. I learned that Toro uses an unusual two layer washer on the front wheels. You need a) either an exact replacement for this washer OR b) two separate washers. The hole of the washer is 3/8" Everbilt has the smaller flat washer PN 637-009 and the larger washer can be found in the Everbilt PN 281-293. The SMALLER washer must be placed closer to the frame, the larger washer is closer to the wheel. Once this was done it ran perfectly. Later I found pieces of the original washers in the grass. Toro had the replacement washer available on their website, I was just in a hurry to get the mower back up and running. The Everbilt washers were purchased at Home Depot.
4/18/2021 12:06:10 AM • Toro Lawn Mower... • Answered on Apr 18, 2021
2answers
What length is a deck belt on a toro lx460
1/2" x 90" ; Toro P/N 112-5834
Try:
http://www.tractorsupply.com/outdoor-power-equipment/mowers-attachments-accessories-parts/mower-parts/mower-belts/huskee-v-belt-1-2-x-90-in-4461290
for $19.49 if you have a Tractor Supply Company nearby.
Or:
http://www.texasmowerparts.com/catalog/products.asp?ds=DETAILED&category_id=47&group_id=184&section_id=585
# Replaces Toro 112-5834 # 1/2" X 90"
for $14.17 + $5.95 shipping
Danotex
3/15/2021 4:11:35 AM • Toro Lawn Mower... • Answered on Mar 15, 2021
Toro self-propelled mower will not
Yes you can just unhook the wire and see if you have spark then, only thing is if it is the kill switch then you will have to replace it or you won't be able to shut your mower off unless you choke it but that will eventually wash the oil from cylinder causing premature cylinder wear, hope this helps you
6/28/2019 5:41:58 PM • Toro Lawn Mower... • Answered on Jun 28, 2019
Ihave a toro rideon 17.38HXL model
carb is probably dirty. an out of adj governor will make it rev high.
11/2/2018 5:38:02 PM • Toro Lawn Mower... • Answered on Nov 02, 2018
My Toro SW5000 zero turn will not turn :
make sure your tires are at proper pressure first. then you can google how to adjust the drive linkage.
11/2/2018 5:34:17 PM • Toro Lawn Mower... • Answered on Nov 02, 2018
Toro Mower -Wheel Horse 210 Hydro Trans. When it
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure. Here is the link - Best Manuals
9/17/2018 6:35:31 AM • Toro Lawn Mower... • Answered on Sep 17, 2018
2answers
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
6/11/2018 12:30:01 PM • Toro Lawn Mower... • Answered on Jun 11, 2018
2answers
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
5/31/2018 6:56:40 AM • Toro Lawn Mower... • Answered on May 31, 2018
3answers
Toro 149cc Lawn Mower Won't Start
Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging.
4/25/2018 11:35:42 PM • Toro Lawn Mower... • Answered on Apr 25, 2018
Have a Toro Personal Pace 190 cc electric start
battery or cable problems When using the battery , there is insufficient power left to run the ignition system when pull starting what is in the battery is sufficient to start the engine
2/21/2018 1:20:12 AM • Toro Lawn Mower... • Answered on Feb 21, 2018
My mower is a 20588 model serial#7034759 and is
Find an identical model on eBay for a lower price than a new mower, and use it for parts, or switch parts if the eBay model is in better condition. Since it is from 1987 before many of us were born, as stated in the Star Trek tv show, "Its Dead, Jim."
2/20/2018 4:43:43 PM • Toro Lawn Mower... • Answered on Feb 20, 2018
I have a toro 3450 snowblower and it is going to full throttle
Sounds like the adjustments need to be worked on outside the carb. If they are dry put a little bit of light oil or even WD40 on all the moving parts on the carb. Sometimes they just get dry and a little rusty from sitting.
2/17/2018 2:37:09 AM • Toro Lawn Mower... • Answered on Feb 17, 2018
3answers
Lawnmower starts runs for 3-5 seconds, then shuts
Clean the carb. The old gas gunked up the orifices.
2/15/2018 9:19:21 AM • Toro Lawn Mower... • Answered on Feb 15, 2018
I have a toro lawnmower model 26624. I think the
i dont know your model but most drive belts are located under the seat you may have a tenson spring problem
1/30/2018 2:21:20 PM • Toro Lawn Mower... • Answered on Jan 30, 2018
Craftsman mower gas leaks into air filter
overhaul the carby , paying to something holding the needle off the seat and flooding the engine
1/28/2018 5:07:27 AM • Toro Lawn Mower... • Answered on Jan 28, 2018
2answers
Have a toro wheel horse
check fuel in the tank check for blocked filter in the tank check for full fuel flow to the carby overhaul the carby
1/9/2018 9:34:27 PM • Toro Lawn Mower... • Answered on Jan 09, 2018
Toro Lawn Mower With Toro Power Tools Logo
1,443 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
toro 6 5 gts start after taking blade
  • Garden
