20 Most Recent
Makita HM1100C Electric Demolition Hammers Questions & Answers
How to fix
193243-2 revision maintenance service kit
With all necessary rings and fat , beware before ordering an service kit take the time to remove all parts of the spindle ringing on the hammer tube spindle for cracks the chisel sds impact bold striker must be even air-tight on the chisel impact bold not leaking grease out of it , if its leaking the air flow will burn the o-rings in a very early time because of the building heat made by the leaking airflow . and loose of lubrication. fat grease .
Tool wont scrape
254031-3 pos14 part inlay key can be damaged pos 11 drive rod 315146-2 can broken IF mechanical damage or dried out by leaking gasket / orings.
For better repair use after a repair of some parts an maintenance kit
193394-1
If the working hours are on it, but also after an repair on other parts because leaking tools can be dried out and give cured o rings in a very short time by building up overheat temperature inside and will not build up pneumatic power it will not do the job and is not good for physical strain.
How to grease a makita mt m8600 demolition hammer
Order an maintenance kit for it , when the working hours are on the tool , all given parts in the kit must be replaced its not a good idea to only grease it, the tool should not leaking by the chisel. then there will be a bad break-force and give a long working job..
HOW GOOD IS H65SB2 HITACHI?
As long as its last and the endurance of the worker in first place .
Its better then use rotating hammers at a long lasting working order , because of the price the choice of a demolition hammer is always a great difference because of the time you can spend , there are much Chinese models look a like this hammer its popular also bosch models you will see .
chinese demolition Google zoeken
Where do I ad oil to a makita hm1500 demolition
Go to
http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
