20 Most Recent
Stanley Bostitch MIIIFN Flooring Nailers Questions & Answers
Looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/
Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format.
Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
I have a bostich Mk 111
Disassemble, clean and lubricate it. The adhesive that holds the nails together gradually builds up on the actuator mechanism and finally stops it. I usually use "Goof Off" or carburetor cleaner to remove the buildup, then lube it with air tool oil.
How to adjust depth on bostich mk111fs
There is no depth adjustment on this tool -
If the staples are going too deep - most likely the piston (#17) has threaded off the driver inside the tool, you have a broken piston bumper (#62) inside, or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
If the staples are not driving far enough - most likely you have a broken / chipped driver blade (#21) or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
Detail
Just had gun rebuild by
Most likely the piston (#15) has partially unthreaded from the piston stem (#17) - this requires a complete teardown to rectify. Sometimes it is simply because use has caused it to loosen - it can also be because the piston has stripped.
Also check your bumper - if it is worn, or in pieces the driver will overdrive.
Damaged driver
You have to take both the cap off and the bottom nose off.
When air is hooked to stapler it leaks from
If the nailer is leaking from the area you discribe, the unit needs to be overhauled as the o-rings are passing air. The kit you need is an ORK-6 O-ring kit. Any Bostitch dearler should have them.
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
