20 Most Recent
RCA L32HD31 32 in. LCD HDTV Questions & Answers
I have an RCA L32HD31 HDTV LCD TV. I am trying to
Be sure to update all the drivers! I have installed many set-ups like that and most often, I need to do all the updates to make everything work. Sometimes HDMI is even more troublesome. If you go that route, be sure to purchase it at a place that allows returns on such items. Best Buy and Staples, are a couple that are usually pretty good about that. You might want to ask a "Geek" at Best buy and see if they have further input on this.
Remote does not work when i change channel on side of tv can only get 3 40 60 and 90
Try a hard reset to this TV, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
