20 Most Recent
Samsung L200 Digital Camera Questions & Answers
I have lost my charger
Here you go.
Buy.com
http://www.buy.com/prod/slb-10a-1050mah-battery-charger-for-samsung-l200-l210-wb550-tl9/q/sellerid/27726616/loc/111/217289838.html
Amazon
http://www.amazon.com/Samsung-Camera-Charger/dp/B001K9SM2I
I currently have samsung
You can
recover lost photos from memory card of your digital camera with this
1. Do not save any new photos into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Samsung L200 webcam?
Can I use my Samsung L200 Digital Camera As Web Cam?
What de software were needed?
Solve my Problem Plz..............
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
