20 Most Recent
Fuji FinePix S1000FD Digital Camera Questions & Answers
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
I deleted photos ,on the
First of all, you should stop saving any new files to you canon camera (or SD card) or taking new pictures with you camera.
Then find this card recovery software here
Here are the steps:
Step 1: Download and install the Digital Photo Recovery Software fromhttp://www.asoftech.com
Step 2: Connect your camera (or SD card, memory card etc) to you PC
Step 3: Scan the source drive where your lost pictures located.
Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
My FINEPIX S1000fd fujifilm camera ZOOM ERROR
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
There is a grid of lines in my lcd screen
Is this a problem? The framing grid is there to assist you in lining things up, getting the horizon level, etc.
If you don't want it, press the DISP/BACK button repeatedly until you get the view you want.
Powers on then shuts off
No such thing as a reset button you can use after you dropped the camera. But the first reaction should be, check where the damage is. If you have any damage on the lens (barrel) you should solve that. If the lens can't move the camera will shut down to prevent any damage to the moving parts of the camera.
Then remove the battery. leave it out for a few moments and then reinsert the battery. Switch it on again.
If it continues to switch off, i'm afraid it really is damaged a lot.
Think what to do, let is repair or buy a new camera. First check what they will charge you for repairs.
A Work Around For Dealing With a Broken Power Switch
Others have had this same problem, the plastic power on/off slider switch eventually breaks (absolutely ridiculous that it happens at all, and I treated mine very gently).
I was going to throw mine out, then remembered that you can power the camera on by holding down the green arrow button (picture viewing button) on the back for two or three seconds. Unfortunately that doesn't seem to work to turn it off, so you just have to set it to power off after two minutes.
Not a great solution, but better than throwing it away, and better than wasting money to have it repaired (if that's even possible).
Fix read error sd card
Not sure you tried all the things I should do.
Be sure the cards are formatted, and try to format them in the camera.
But before you put in any card, check with a bright light close to the memory card slot, if all the contacts are clean and free, Just a little bit of dust or paper on one contact, could spoil all the fun. The contacts should be clem and shiny. All straight and to one side, Not one can be a little bent. If someone ever pressed a memory card in the camera the wrong way around, a lot of damage should be seen down there with some contacts bent or broken.
And be sure you did not switch all the cards to the lock position.
