20 Most Recent
HP Designjet T1100ps Printer Questions & Answers
When I turn on my
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..Led pattern: Power supply LED as 1Formatter leds 3nos from left to right as 2,3 & 4..* indicates "on"# indicates "off"& indicates "flashing"* # # # ....Main PCA* * # # ....Formatter* $ # # ....Hard disc* * * $ .....Main PCA or FormatterNote down which LED are on.off & flashing,compare with above said indications find out the faulty part..
Error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
Replace the Starwheel Motor → Page 8-167.
If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
HP designjet t1100ps error 21:13
This is a service station error indicating that the printer could not move the pirnthead mechanism over the service station. First check to see if there is anything in the carriage path such as a piece of paper blocking the carriage. If there is not then it is likely a bad service station that will require replacement. Always try powering pirnter off then on to see if it was temporary error.
Hp designjet t1100 blank hard drive installation beware spam number 1*800*532*4187
Hello. Designjet T1100 disk failures are pretty common. HP has made it difficult to do anything with their HDDs by securing them with passwords. When a new HDD is installed, it also takes on the ID of the plotter and refuses to work in any other plotter from then on. LPS Computer has T1100 hard disk drives that have been modified to install and work properly and they cost less than HP is asking. They can be seen here: http://www.lpscomputer.com/collections/designjet-t1100-t1120-parts
I am receiving error message of : 86:01 Possible paper jam
Most times when this error occurs it is because of one of three things:
1. Paper jammed in the carriage path that prevents the printhead from moving all the way from left to right. Check closely on the far left and right as paper can be pushed into the interior of the printer by the service station.
2. The printhead cover was not closed properly and the metal ring that that the blue handle is supposed to engage in is catching on the side of the printer.
3. The drive belt has either come off the track or broken. Open the lid and check the black rubber belt that drives the printhead assembly. It should be taunt. If it is loose there is a problem. I have had several 1100 series designjets throw their belt off the tension pulley. You can sometimes reseat it but my experience is that it will get thrown again. If you replace the belt, replace the tensioner at the same time.
21.13
For tech guys only :Open right side door, check any obstruction in service station while moving.Check service station connection, re-fix once again.. checkRemove service station, remove motors, clean entire service station with water, ensure that entire ink should be washed out allow it for dry, apply grease to the moving parts, fix it back, check...( cleaning service station is very dirty work be prepare for that). check.. Replace service station...
What am i supposed to do when i'm getting error 44:10
System Error
44:10
Problem Description
Problem with the Aerosol Fan
Corrective Action:
Reboot the Printer. Check the Aerosol fan cable is not damaged, Replace the Aerosol Fan, if error continues, Replace Interconnect PCA
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Hp designjet 800 does not recognize black cartridge.
it is quite common for the chips on the ink/printrhead cartridges to fail, I would recommend you contact the supplier and inform them of the failed chip and they will likely send a replacement, unfortunatly there is no other way round this other than to have the cartridge replaced, again. if however after the second cartridge faile to be recognised then the ISS Pca may need replacing but unlikely,
