20 Most Recent Brother MFC-7440N Laser Printer Questions & Answers
3answers
My brother mfc 7440N prints splotches every 3-3.5" on every page printed. This occurred with the previous and new toner cartridges. How to fix?
For crying out loud. The "blotch" is caused by damage to the drum or to the toner fusing roller. If the "blotch" is loose toner (in other words you can smear it) then the fuser roller is damaged and that assembly needs to be replaced. If the "blotch" is fused (in other words you cannot smear it around) then the drum is damaged and that assembly needs to be replaced.The original MSRP for the Brother MFC-7440n in 2008 was $429 (US) / 213 pounds [FixYa couldn't handle the pound sign!! =8-) ] (UK) / $499 (AU). The present street value is about $199 according to Brother ( http://www.brother-usa.com/MFC/ModelCompare/4/MFC7440N_MFC7460DN#.UXBKKKLq3yA ). A drum unit is $80 (Amazon) or $115 (Staples).That same $200 could get you a Canon Pixma MX-922 (Canon http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx922). Inkjet? Yes. But fast. Airprint. 2-sided ADF and copying. Auto-duplexing. CD/DVD disc printing. Frankly, if I didn't already have an Epson 835, I would buy this one. My old Canon 820 still chugs along as beautifully as the day I got it (about a zillion years ago).For $50 more you can get a top-rated laser, their imageCLASS MF4880dw (though oddly, without Airprint - for Airprint in a Canon laser, you have to step up to the big boy: the imageCLASS MF8580Cdw).. Well. Have fun!
8/22/2019 12:48:34 PM • Brother... • Answered on Aug 22, 2019
Copy button is not working on a brother MFC 7440N
Disabled display panel and clean pannel
4/14/2019 3:22:59 PM • Brother... • Answered on Apr 14, 2019
Brother reset toner ended brother mfc-7470d printer
PRESS MENU START - + - + - + MACHINE SHOWS MAINTENANCE MODE THEN USE UP AND DOWN KEY PRESS 88 OK RV OK REVEAL OK PRESS OK THEN MACHINE AUTOMATICALLY RESTART AND AFTER THAT ALSO SET COUNTRY SETTING GO TO MAINTENANCE 74 OK ENTERR 0045 THEN PRESS START AFTER THAT OFF AND ON MACHINE AND ENJOY
4/14/2019 3:14:21 PM • Brother... • Answered on Apr 14, 2019
How to install brother printer without cd
You can go to the brother website and download the driver/software package to you PC and load it from there. Here is a link to the page. Simply select your OS and click the SEARCH button. It will display the packages available for download. Download the one you need and execute it. http://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=mfc7440n_all
10/23/2018 9:59:10 AM • Brother... • Answered on Oct 23, 2018
Original document fed into top feed tray of MFC 74...
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
1/20/2017 9:21:13 PM • Brother... • Answered on Jan 20, 2017
I can not pullout drum
brother likes to use green colored locking levers look for levers to release drum
3/25/2016 10:44:26 AM • Brother... • Answered on Mar 25, 2016
It only prints everything in grayscale. I cannot find the preferences where this changes. No option in "Printing Preferences". Any idea?
The MFC-7440N is a mono (i.e. black toner only) laser printer, so it has no colour printing capability.
2/3/2016 1:50:39 PM • Brother... • Answered on Feb 03, 2016
Printer is back and white, print is faded, toner is fine. What could the problem be?
Most likely it is an issue with the Drum Unit. Start by cleaning the Corona Wire. There will be a slider on the top of the Drum Unit. Slide it all the way to the other side and back to where the arrows meet and try your print again. If this does not fix the problem replace the drum unit as the drum itself may be worn. The drums are rated to do 12,000 pages and it has probably done this. 12,000 pages equates to about 5-6 cartridges.
10/15/2014 4:08:59 AM • Brother... • Answered on Oct 15, 2014
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
8/17/2014 6:51:53 AM • Brother... • Answered on Aug 17, 2014
What can cause a bad burning smell coming from the printer whenever I use it
It might be the heater not getting enough power. Check and see if the Printer is directly plugged to the wall outlet or to a power regulator. If it is powered through a power regulator then try plugging it directly to the wall and see if the problem is solved. You might wanna check the voltage power of both the printer and the outlet before you go on with this.
7/15/2014 9:09:14 AM • Brother... • Answered on Jul 15, 2014
How to reset Drum
First Open the front cover while the power supply of the machine is ON, Then Press the Clear/Back button. Then Press the 1 button. Then Close the front cover. Good Luck
6/11/2014 5:34:27 PM • Brother... • Answered on Jun 11, 2014
Drum and Power On
Have the printer "Fuser" tested. It might be the reason behind that.
4/16/2014 1:03:36 PM • Brother... • Answered on Apr 16, 2014
0answers
There is no power
try to replace new power supply, or check first the cable,
3/6/2014 4:54:33 AM • Brother... • Answered on Mar 06, 2014
0answers
0answers
Brother MFC-7440N Laser Printer Logo
212 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
no power
  • Office Equipment & Supplies
