20 Most Recent
LG 32LG30 32 in. LCD HDTV Questions & Answers
I don't now how i
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
I can not get teletext on my tv lg flat
you should press the home button of your teletext page usually its 100
or you could press one of the four colored buttons o your remote control unit so it will reset to the home page of the teletext
(a black page mostly says that teletext isn't available to the specific channel )
LG 32LD550 power cyles when using HDMI inputs
Do a
hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset).
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Water damage lcd lg tv
The problem is the buffer board located on the bottom of the screen is burned out. The TV need a new LCD display panel.
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Which button turns on subtitles
If you have a digital Set-Top Box with digital cable service:
Using Navigator:
- Press the SETTINGS button on your remote.
- Scroll left or right to the Quick Settings category.
- Scroll down to select the Closed Captioning option and press SELECT.
- Scroll up or down to highlight On, On with Mute, or Off and press SELECT.
Using i-Guide:
- With your Set-Top Box currently on, push the POWER button on your Set-Top Box to turn it off.
- Immediately-within one second-push the MENU button on your remote. You should see a User Settingsmenu screen displayed.
- Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable.
- Power on the Set-Top Box to return to watching TV.
Otherwise, if you have basic cable, please consult your television's user manual for instructions to turn on/off closed captioning.
LG 32LK330 32 LCD TV one vertical line
The t con board or the LCD panel is faulty. Can confirm by replacing the TCON board. Sometimes bad connections contacts can cause e such problems. Before replacing TCON board detach all the connection to it and ten reconnect it and then check whether the line is there or not.
http://electro-medical.blogspot.com/
