20 Most Recent
LG 50PY3D Plasma TV Questions & Answers
Black blank screen
IF YOU HAVE SOUND ITS A BIG POSABILITY THAT EITHER YOUR YSUS OR ZSUS PANEL IS FAULTY.A GOOD INDICATION IS TO CHECK THE FUSES ON THEM.THERE ARE FUSES AND SOME OF THEM IS SMALL AND MIGHT BE MISTAKEN FOR A RESISTOR.IF THE FUSES ARE BLOWN THEN U KNOW THAT PARTICULAR BOARD IS FAULTY BECAUSE ITS VERY RARE THAT A FUSE BLOWS WITHOUT A REASON.IT BLOWS BECAUSE OF OVER CURRENT DUE TO A SHORT CIRCUIT
Tv turns itself off immediately
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Hi i have a 50
This could be a board or the panel. It is hard to say. Both can cause this. Have a repair shop check it out.
