20 Most Recent Minolta bizhub 200 Copier Questions & Answers
Tinta pada minolta bizhub c200 boros
what is the issue????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 8:47:46 PM • Minolta bizhub... • Answered on Jan 24, 2016
Fax sent auto-reduction...sents small fax
try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/22/2015 12:57:25 AM • Minolta bizhub... • Answered on Nov 22, 2015
Bizhub 200 C11a0 error
Exit Paddle Solenoid (SL2-FN) Exit Paddle Home Position Sensor (PC11-FN) Main Control Board (PWB-A FN) one of the above on the finisher is not working or is jammed Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/19/2015 3:35:22 AM • Minolta bizhub... • Answered on Nov 19, 2015
I need to reset admin
utility/counter stop 00 stop 01 go to Settings in the Administrator # Initialize and change pw Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/14/2015 10:43:55 PM • Minolta bizhub... • Answered on Nov 14, 2015
Need help changing default copier paper size from
go user settings/choice setting tab #6 set default tray to what you want Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 12:58:03 AM • Minolta bizhub... • Answered on Feb 22, 2015
Where is the OPC drum located on a bizhub 200?
Inside the image unit. which is the assy in the machine right side cover that has the two handles on the green looking item Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 4:49:13 AM • Minolta bizhub... • Answered on Feb 19, 2015
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 12:24:52 AM • Minolta bizhub... • Answered on Feb 19, 2015
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/31/2015 11:37:25 PM • Minolta bizhub... • Answered on Jan 31, 2015
Touch screen not working
Try this first if it does not work you need a new screen/control panel. 1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/4/2015 4:39:18 AM • Minolta bizhub... • Answered on Jan 04, 2015
How do I print the journal of faxes for a specific day
Sir/Mam, Go to 1. Admin Management 2. Admin #1 3. Reports Settings and or Print list that should give what you want. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 9:54:26 PM • Minolta bizhub... • Answered on Dec 30, 2014
HOW TO REPLACE PAPER PICKUP ROLLER
Bypass tray? or draw? which one? or large capacity draw? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/6/2014 10:45:12 PM • Minolta bizhub... • Answered on Dec 06, 2014
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2014 10:46:33 PM • Minolta bizhub... • Answered on Jul 04, 2014
Paper type for 8.5 x 11 paper was reset to A4. I
I would start with the easiest solution, look to see if there is any paper jammed behind the paper tray. There are switches behind the paper tray for paper size. Also, make sure the paper tray guides are in the correct position against the paper in the tray, they tell the copier the paper size. Good Luck
12/24/2013 2:46:23 PM • Minolta bizhub... • Answered on Dec 24, 2013
Code sc35-02 on biz hub pro c500
My Bizhub pro 920 Error Code SC35-02
7/23/2013 2:08:56 AM • Minolta bizhub... • Answered on Jul 23, 2013
2answers
Bizhub 200
problem in hv unit ( ch corona ) in drum unit replace if necessary
1/20/2013 12:51:34 PM • Minolta bizhub... • Answered on Jan 20, 2013
[email protected] I
Use the hand feed tray on the right side. When you put paper in this tray it usually will ask you to set the paper type. 110 lb. card stock is EXTREMELY difficult to copy onto. It might be better to bring this particular job to a copy center. This type of stock will put serious wear on your machines drum. Drums cost big money. Good luck.
7/15/2011 8:33:32 PM • Minolta bizhub... • Answered on Jul 15, 2011
Where can I find
Press the "utility" button.
1/5/2011 1:35:12 AM • Minolta bizhub... • Answered on Jan 05, 2011
My bizhub 200 has message
This means that imaging unit of your photocopier machine should be replaced.its life is over now.
10/7/2010 1:22:36 PM • Minolta bizhub... • Answered on Oct 07, 2010
Minolta bizhub 200 Copier Logo
Popular Tags
32 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
code sc35 02 biz hub pro c500
  • Office Equipment & Supplies
