20 Most Recent
Venta Airwasher VS370 2 Gallon Humidifier Questions & Answers
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Why does my humidifiers does not have any smoke
My Guess is that the reletive humidity in the room is not low enough to see any vapors coming from the machine. Normaly you won't see these anyway. Some models in the stores seem to make more mist than what you get at home. If the humididty level in a room is close to what is coming out of the machine there will be no signs of any mist coming out. Just make sure the filters are clean and check and make sure the water level is going down on the machine and this will tell you its workin. the faster you are using the water in the tank the more you are putting in the air! If this is a hot mist machine then I would say the heating element in the machine is not working.
How often do i need to change the filter?
From the quick research that I did I'm finding 100 hours. That will vary very significantly depending on the mineral content (hardness) of your water. If you have alot of mineral in your water the filter may have to be changed much more often to maintain good operation of the unit.
I have a Venta VS370 humidifier which works fine
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Venta humidifiers not cleaned after past season
Every 10-14 days, the lower housing should be wiped out with a damp sponge. The disk stacks
should be rinsed off and/or brushed off with a brush or sponge. Periodically, the Venta Cleaner
can be used for a thorough cleaning. At all times, care should be taken to keep water away
from the motor.
I have not used my
As awkward as it sounds tap water is bad for the unit, Try buying store bought water. If this does not help you will need to change the filter in the system also you can set the desired humidity level to 60% so it will keep pumping if you still have an issue with the product refer to your manufacture. Good Luck
5/15/2013 9:37:29 PM •
Venta...
Answered
on May 15, 2013
