20 Most Recent
Mitsubishi WD-73736 Television Questions & Answers
How to set up for 3d viewing
You need a 3D Blue ray player and 3D glasses. Make sure that the 3D feature is turned on on your Mitsubishi. You also have to have HDMI 1.4 cables. Anything lower will not produce 3D
Does any offer a longer lasting bulb I replace it
HI:
The normal usage time for lamps are 6500 hours, thats a little under three years depending on the use of the television, These lamps last longer when they are not turned off and on all the time. The constant heating and cooling prematurely wears out the lamp, also on Mitsubishi lamps have a filter on their lamps that geta cloged with dust from the exaust fan, causing heat to become traped in the lamp compartment which will cause the lamp to blow premautrely, using a compressor try cleaning this filter every 6 months or so for longer llamp life.
Mitsubishi 73 inch. green light blinks for a few
Mits has had an excessive number of problems with color wheels in some of their optical engines. Provided you replaced the lamp with OEM parts I would suspect the color wheel is causing the noise as well as the shutdown issues.
Bill W
integrityhomeworx.com
When i try to change
Have you tried the soft reset for this set? Menu, 1,2,3 enter? There is also a hard reset in the hidden Option menu you can try.
Let me know as much as you can.
SD TECH
