20 Most Recent
Mitsubishi WD-65736 Television Questions & Answers
Mitsubishi dlp tv picture is getting darker
One of two possible issues:1. Lamp is nearing end of life and may dim just before total failure.2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.If it has 2 mirrors I can tell you exactly how to get at it.SD TECH
Status light red
The problem is most likely the lamp.They usually last 2-3 years if original.I hope my answer was helpful :)
10/10/2013 12:01:25 AM •
Mitsubishi...
Answered
on Oct 10, 2013
Blinking status green light red
The most common issue for this TV is the lamp.If the current lamp in the TV set is around 2-3 years old then I would start with that. If the lamp is not original they only last about 1 year.If you already replaced the lamp recently the next step is the ballast.I hope my answer was helpful :)
10/10/2013 12:00:10 AM •
Mitsubishi...
Answered
on Oct 10, 2013
Status light flashing
You have the V39 Chassis and if the status light is blinking Red then its indicating the fan has stopped. There are more than one you can get the assistance to determine which one you need from
www.tvrepairworld.com and they also have the replacement fans that come with installation instructions.
