20 Most Recent
Mitsubishi WD-60735 Projection Television Questions & Answers
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
I have a Mitsubishi wd-60735 TV. it is in an unheated garage. Will the cold winter temperatures damage anything? Do I need to bring it inside?
it used to be an issue from when older projection TV's were fluid cooled , but modern lcd projection tv (like this one) don't have any issues in cold weather other than it will take several minutes till picture comes into focus in extreme cold weather , but should not give any long lasting effects once its up at operating temps one thing though don't move it once its hot during cold weather or lamp light source will go out , one thing that will cause long term problems is if its subjected to high humidity (water) this causes all sort of corrosion problems in sets of all types
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
How do you clean inside the screen of my TV
You can use compressed air but it will leave the dust inside. If you remove the bezel you can take the front face off and clean it that way. I would not recommend using cleaning solvents to clean the screen use a dry cloth. The screws are on the back side along the edge of screen.
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.The soft reset "should" be with set on Menu, 1,2,3, enterThe hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
