20 Most Recent Viking 37 in. VGSU161 Gas Cooktop Questions & Answers
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
6/11/2014 11:06:09 AM • Viking 37 in.... • Answered on Jun 11, 2014
I have a Viking VGSU161-6BSS stove top the ignitors stop working and now smoke was comiong out from where nobs are
The igniter pack has fried itself and needs replacing, it may have also burnt wires.
5/11/2014 12:20:04 AM • Viking 37 in.... • Answered on May 11, 2014
Two of the 6 knobs on my gas cooktop are stuck and
Pull the knobs off
Spray some WD40 or release oil on the shafts , wrap a piece of tissue around them first to alow the stuff to soak in
Give it a couple of houts then get a pair of pliers and gently lift them up and down until the come free
If need be apply some more WD40 as you do that
12/6/2013 12:42:13 PM • Viking 37 in.... • Answered on Dec 06, 2013
No clicking noise when I try to light any burner
Hi,Check power to cooktop first to assure it is not the issue. If not the issue, the spark module is the cause of all the burners not working. If only one burners its a burner switch, if more than one burner its the module that needed replaced.I hope this helps. I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
10/15/2013 9:43:51 PM • Viking 37 in.... • Answered on Oct 15, 2013
I have a 6 burner range top. When I turn on 5 of
Hi,The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.I hope this helps. I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
10/15/2013 9:41:03 PM • Viking 37 in.... • Answered on Oct 15, 2013
Burner will not ignite but
I have had this same issue with continuous sparking after a burner was lit. Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problemProblem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).Mike S
12/3/2012 9:11:50 PM • Viking 37 in.... • Answered on Dec 03, 2012
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
9/30/2012 10:51:17 PM • Viking 37 in.... • Answered on Sep 30, 2012
Clicking noise won't stop once
Hi
There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module which should be replaced as sometimes cleaning can get moisture into the surface switches; try drying them with a hair dryer to see if this will help. Hope this helps...please post back for further assistance.
Daniel
10/26/2011 10:58:41 AM • Viking 37 in.... • Answered on Oct 26, 2011
The unit continually sparks even the gas is turned
Hi stevebauman,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
9/25/2011 9:31:22 PM • Viking 37 in.... • Answered on Sep 25, 2011
All six of the ignitors
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
8/16/2011 5:30:10 PM • Viking 37 in.... • Answered on Aug 16, 2011
Constant clicking on the burners.
Hi
As you have already tried to clean everything and even the igniter switch and blown warm air using a hair dryer around the shafts where the knobs attach, so it means the issue is either with a bad gas valve or the igniter itself going bad. Hope this helps...please post back for further assistance.
Daniel
6/19/2011 12:56:53 PM • Viking 37 in.... • Answered on Jun 19, 2011
Once burner lights the "clicking" of the ignition
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
2/1/2011 5:39:46 PM • Viking 37 in.... • Answered on Feb 01, 2011
Same thing, can't figure out how to get it apart.
Viking has a "special" (ha,ha) tool that you put across those 2 notches in the center brass ring. You can find this wrench with pics at: allvikingparts.com/BT_SBW_Sealed_Burner_Wrench_s/138.htm
You probably have thrown out many similar looking 'free' wrenches(because we have better ones in our toolbox) that are packaged with kids toys etc. that should do the job.
A hand held steamer has done a pretty good job for me in cleaning the burned on gunk. I have also used my dremel with various different polishing tips when I have been really frustrated with gunk and discoloration.
12/12/2010 5:28:56 PM • Viking 37 in.... • Answered on Dec 12, 2010
How to clean baked on crud off the metal part of
It is aluminum and it is a pain to clean. Use a Magic Eraser sponge by Mr. clean and order so Star Clean (only available on the web from TJT products) and it will clean it right up. I tried everything too and couldn't get anything to work. I was seriously considering getting rid of the cooktop but this combo did the trick.
10/26/2010 1:40:52 PM • Viking 37 in.... • Answered on Oct 26, 2010
0answers
Viking 37 in. VGSU161 Gas Cooktop Logo
38 questions posted
Top Viking Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Viking Cooktops
  • Viking Cooktops
Most Popular Question
6 burner range top when turn 5
  • Cooktops
