20 Most Recent Viking VUWC141 Wine Cooler Questions & Answers
Viking wine refrigerator flashing red light
what is the model number is then we can get started then okay??
9/12/2013 1:03:41 PM • Viking VUWC141... • Answered on Sep 12, 2013
0answers
Defrost
Be the first to answer 6/12/2012 11:56:26 PM • Viking VUWC141... • Posted on Jun 12, 2012Be the first to answer
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
6/4/2010 2:55:42 PM • Viking VUWC141... • Answered on Jun 04, 2010
Fan constantly running on top of viking refrigerator , vcbb363 bottm mount freezer
It sounds like there may be an issue with the fan or the control board in your Viking refrigerator. The constant running of the fan, even when the compressor is not running, is not normal. The fact that different repair technicians have given different diagnosis and the issue persist even after replacing the compressor fan motor, suggest that it may be a problem with the control board, which manages the refrigeration system, including the fan. It could also be a problem with the thermostat, or the system's settings. Since the fridge and freezer seem to be at normal temperatures, it may not be a problem with the cooling system. It's best to contact Viking customer service for further assistance and see if they can provide any additional information or troubleshooting steps. If the issue persist, it's best to ask for a senior technician or supervisor to take a look at it and provide a resolution.
9/29/2023 7:15:33 PM • Viking... • Answered on Sep 29, 2023
How to replace ice maker signal arm
  1. Safety First: Before you begin, unplug the refrigerator from the electrical outlet to ensure your safety.
  2. Locate the Ice Maker: The ice maker is typically located in the freezer compartment of your refrigerator. It's usually mounted to the side or top of the freezer.
  3. Access the Ice Maker:
    • In some refrigerator models, you may need to remove the freezer's interior shelves or baskets to access the ice maker.
    • Others may have a cover or panel that needs to be removed to access the ice maker assembly.
  4. Identify the Signal Arm: The signal arm is a slender, plastic or metal arm that is connected to the ice maker assembly. It extends over the ice bin or tray.
  5. Remove the Old Signal Arm:
    • If the signal arm is attached with a screw, use a screwdriver to remove it.
    • If the signal arm is connected with a clip or latch, gently detach it by carefully pulling it off the pivot point. Some signal arms may have a small locking tab that needs to be released first.
9/6/2023 8:38:58 PM • Viking... • Answered on Sep 06, 2023
Viking Built-In Refrigerator Not Sealing Intermittently
Check the door gasket for torn or broken attachment tabs. Gently go all the way around the door gasket, wiggling it to see if any part of it pulls out of place. If you find a build-up of dirt, mold, etc,. clean that off. If there is mold present, clean it with a borax solution. Also check the door frame on the refrigerator shell where the gasket is supposed to seal. If you see one area that is particularly dirty or signs of frequent condensation, double check the corresponding part of the gasket for defects. I'm hypothesizing that a broken section of the gasket sometimes rolls or moves sideways, thus preventing proper sealing. I have also had problems with the door staying closed if something in the freezer or refrigerator sticks out just enough to put outward pressure on the door (or a similar protrusion of items in the door racks). In that case, re-arrangement of the freezer contents should fix it.
8/16/2023 5:27:26 PM • Viking... • Answered on Aug 16, 2023
Do you have to use Viking Wine fridge parts to fix a Viking Wine cooler?
Hi, I wouldn't pay upfront because the repairman doesn't know what the main problem is. You can first reach out to the product's manufacturer for recommended repair vendors. But if this fails, then you can call your nearest Lowe's or Home Depot for parts and repair assistance. Thank you.
12/24/2022 9:39:14 AM • Viking... • Answered on Dec 24, 2022
Can I replace a Viking DFBB363L low voltage control board myself?
seems to me he is a crook, (aka a scalper) why not buy one cheap and put it in. the online manual free shows the parts inside many Refers only have timer clock for defrost timer job. as you can see the year matters for this board. nov 2003 cut off. see this gem http://allvikingparts.com/v/vspfiles/downloadables/DFBB363.pdf now shop by the exact part numbers. or call maker and ask for qualified repair shop>? in what country I do not know, not told. and parts are best obtained close by, no down time. my guess wild he means part ID #5"? G50911837LOW VOLT / HIGH VOLT BOARD KIT (BEFORE 11/17/03) (BEFORE 11/17/03) G50911826LOW VOLTAGE BOARD KIT (AFTER 11/17/03) (AFTER 11/17/03) 5G50911826LOW VOLTAGE BOARD KIT (AFTER 11/17/03) PE970463POWER CONTROL BOARD (AFTER 11/17/03)
7/5/2022 9:31:54 PM • Viking... • Answered on Jul 05, 2022
My Viking Icemaker is leaking.
Eva, it is faulty, call for service. You can't fix these things yourself. Your water inlet valve is stuck open.
6/19/2022 4:16:30 AM • Viking... • Answered on Jun 19, 2022
Viking DFSB423 Refrigerator. How do you remove the front door we need to replace the door stop that broke
Question edited to add the maker. Question moved to Viking Refrigerator Category. No one has done this before so only generic help exists. https://www.google.com/search?q=dfsb423+refrigerator+remove+doors ..
12/30/2021 5:42:54 PM • Viking... • Answered on Dec 30, 2021
Viking refrigerator vcbb363. none of the front buttons work
sad to tell you this but you need a local repair service to test and replace bad control board
6/23/2021 9:14:44 AM • Viking... • Answered on Jun 23, 2021
Model DDSB483DSS 48-inch side by side. Why does the freezer door pop open when refrigerator door is opened or closed?
The freezer door may be misaligned from top to bottom, resulting in poor contact with the magnetic seal. Another possibility is that the hinges are defective or misaligned, allowing the door to pop open.
12/7/2020 3:37:02 PM • Viking... • Answered on Dec 07, 2020
3answers
My Viking D61FFF98 side by side refrigerator leaks condensate on the floor. Condensate pan overflows.
IS THE EVAPORATER FAN RUNNING
11/28/2020 1:25:46 AM • Viking... • Answered on Nov 28, 2020
How to diagnose or repair Viking fridge gas leak
THE AVERAGE PERSON CAN NOT DO IT , CALL A REPAIR SERVICE LOCALLY
11/23/2020 8:49:12 AM • Viking... • Answered on Nov 23, 2020
Viking VUWC141 Wine Cooler Logo
5 questions posted
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Refrigerators
Most Popular Question
viking wine cellar temperature near
  • Refrigerators
