20 Most Recent KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Questions & Answers
2answers
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
3/23/2024 12:49:00 AM • KitchenAid... • Answered on Mar 23, 2024
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
2/7/2023 9:50:59 PM • KitchenAid... • Answered on Feb 07, 2023
2answers
Wont turn on,just blinking light
This will probably need either a new thermal fuse on the field windings or a new motor.
9/27/2021 3:27:18 AM • KitchenAid... • Answered on Sep 27, 2021
I have a Kitchen Aid 5 speed blender. After
Hiya, Sorry to hear you are experiencing an issue with your blender. We believe that the described issue indicates control board fault. If you have KSB555, please follow the link below to show you how to replace this part on your appliance. https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/HowtochangetheControlBoardonaKSB555/tabid/650/Default.aspx https://www.youtube.com/watch?v=Lafh8UGn4No Hope you found this useful :-)
9/12/2019 8:01:37 AM • KitchenAid... • Answered on Sep 12, 2019
3answers
Can't remove the blender blade from the jar
how to tighten nut on kitchen aid blender
9/12/2019 7:58:04 AM • KitchenAid... • Answered on Sep 12, 2019
2answers
Blender is leaking
Buy a new one
9/23/2017 5:16:53 AM • KitchenAid... • Answered on Sep 23, 2017
When I turn my blender on, it runs for only a few
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
3/10/2017 9:00:50 AM • KitchenAid... • Answered on Mar 10, 2017
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
5/9/2016 8:28:16 AM • KitchenAid... • Answered on May 09, 2016
Replacebrokenmagnet
Magnet is not available as a separate part, you need to buy a new motor and be more careful in the future.
4/29/2016 1:19:21 PM • KitchenAid... • Answered on Apr 29, 2016
2answers
Why wont my dishwasher go through the proper cycles
Blenders are not to be used for washing dishes, that may be where your problems are.
8/4/2015 10:39:06 AM • KitchenAid... • Answered on Aug 04, 2015
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
12/6/2014 3:18:06 AM • KitchenAid... • Answered on Dec 06, 2014
Why is the unit not turning on?
Check the motor for continuity, it may be open circuit. If it is locate the thermal fuse covered with insulation tape on one of the field windings (where the metal clip is) Check that for continuity, if faulty bypass or replace it.
10/4/2014 6:27:25 AM • KitchenAid... • Answered on Oct 04, 2014
Removing over the hood microwave
There is no microwave hood on a Kitchen Aid blender
9/7/2014 11:51:41 PM • KitchenAid... • Answered on Sep 07, 2014
Dishwasher doesn't fill and spin
Try asking this in the dishwasher department, asking it in the blender dept will invite unhelpful replies like this 'cos I know nuthin' about dishwashers.
7/26/2014 8:59:05 AM • KitchenAid... • Answered on Jul 26, 2014
How to repair tefal 8143 dough mixer
You could try asking this in the Tefal part of this forum instead of the Kitchen Aid area as folks who know Tefal may not be browsing this area. You could also be a little more specific about exactly what the fault is that needs repairing.
7/26/2014 8:49:17 AM • KitchenAid... • Answered on Jul 26, 2014
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
7/23/2014 6:48:43 AM • KitchenAid... • Answered on Jul 23, 2014
Changing the coupler
Lever it off with a screwdriver, it is aluminium and the threads on the ring will break away. Pick them out of the thread on the motor shaft and screw on a new coupling, it will be left hand thread.
7/19/2014 5:38:07 AM • KitchenAid... • Answered on Jul 19, 2014
0answers
Shorted diode
Be the first to answer 1/31/2014 3:06:35 AM • KitchenAid... • Posted on Jan 31, 2014Be the first to answer
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
77 questions posted
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Blenders
  • KitchenAid Blenders
Most Popular Question
kitchen aid 5 speed blender after
  • Blenders
