20 Most Recent Oster 6058 Toaster Oven with Convection Cooking Questions & Answers
How to replace light bulb in toaster oven model
Suggest go online to YouTube or similar . Follow the steps careful because you are dealing with electricity. If unsure take it to a qualified technician.
10/1/2019 7:06:47 AM • Oster 6058... • Answered on Oct 01, 2019
Clock runs fast -- gains
Digital Clock - Much like a digital watch or a computer, the 12/24 hour Real Time Clock (RTC) digital display clock's ability to maintain time with integrity is most likely on the interior. Flip the unit to view the rear and you'll find a backplate with phillips screws and 4 star bit screws of different size each hidden by black rubber gromits).A Common Battery that can be found at your local retail store:RTC 2032 3 Volt BatteryI can only assume removing the screws would reveal the proper answer, but I wager a standard RTC battery is what you'll find.
9/7/2019 5:21:55 AM • Oster 6058... • Answered on Sep 07, 2019
0answers
Looking for the user manual for my Oster 6058-033
Hi there.
Try http://www.oster.com/ProductManuals.aspx for Owner's Manual download.
Regards.
6/29/2011 1:20:51 AM • Oster 6058... • Answered on Jun 29, 2011
Oster 6058 Toaster Oven heating
You will be able to locate authorized parts and service centers by visiting http://www.oster.com
Regards.
6/18/2011 3:18:28 AM • Oster 6058... • Answered on Jun 18, 2011
I am looking for a
You can get the manual on the link below.
http://www.oster.com/manuals/MANUALS/006058-000-000_43_51447038.PDF
Good Luck
5/22/2011 6:57:14 PM • Oster 6058... • Answered on May 22, 2011
Pizza and oven bottoms are not working but others.
If they went bad maybe they can be replaced. Here is an address that will give you a list of sites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
2/18/2011 8:09:41 PM • Oster 6058... • Answered on Feb 18, 2011
Model# 6058 toaster oven won.t
You need to remove the top cover and check for a bad fuse if no display. If you have display, then it could be a bad door switch, or a bad megaton, or na bad high power Diode.
2/17/2011 7:04:05 PM • Oster 6058... • Answered on Feb 17, 2011
The bottom two heating elements
I do not know everything about every toaster oven out there, but I would guess that they can be replaced. Here is an address that will bring up a list of sites that sell parts. Maybe one of them can be of more help.
2/10/2011 4:25:04 PM • Oster 6058... • Answered on Feb 10, 2011
Wires from the electric cord inside the unit
Yes!
If you are street wise, otherwise qualified electrical appliances repairer. Weight up repair to purchase of replacement?
12/26/2010 8:51:36 PM • Oster 6058... • Answered on Dec 26, 2010
Bottom element will not heat
broken wire or burnt element.
12/20/2010 4:49:15 PM • Oster 6058... • Answered on Dec 20, 2010
2answers
I ned the oven oster manual!!
Ask here, it seems they can get you every Oster manual
12/11/2010 5:32:05 AM • Oster 6058... • Answered on Dec 11, 2010
When I went to use it last week the elements would
hi jackie, the loud noise can be an excessive power drain and that is why the elements will cut off at times. There are some thermal fuses or resettable thermal switches that are built in the oven and will cut the power to the element circuit to protect the whole oven. My suggestion is to have an appliance tech check the unit for this problem because the fuses or switches are inside the electrical area of the oven.
1/20/2010 1:29:50 AM • Oster 6058... • Answered on Jan 20, 2010
I need parts for an Oster 6058 taster oven
I( need a tray and a rack not repairs.
HM
10/2/2009 11:40:57 PM • Oster 6058... • Answered on Oct 02, 2009
Oster 6058 Toaster Oven with Convection Cooking Logo
50 questions posted
Top Oster Toaster Ovens Experts
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
View Most Popular
Oster Toaster Ovens
  • Oster Toaster Ovens
Most Popular Question
looking user manual oster 6058 033
  • Toaster Ovens
