20 Most Recent
General Electric Monogram® ZGU385NSMSS (Gas) Stainless Steel Cooktop Questions & Answers
Center Burner stays lit and will not stop trying
Hello Donna ,If by saying "stays lit" ya mean that the flame goes off when turning off the knob yet it continues to spark all the time ?? if yes that's whats happening the flame goes off but it keeps sparking whats wrong it that the switch that turns on the spark when the knob is turned is bad and that is what needs to be replaced. GE only makes that switch available in a complete assembly with all 5 switches and the wiring for it. It's not to bad to replace that actually,what ya would need to do to replace that switch harness asm. ya need to take off the main top which can be done by removing the burner grates and caps from the burners,then is the outer center of each burner will be 2 screws remove those screws from all burners then the all 5 knobs and the top will lift off,that switch harness has keyed plugs and will only fit in one way so its not to bad to replace it. The part number for that switch/wire harness asm. is WB18T10381 it could be purchased at your local appliance parts store or online at; searspartsdirect.com apdepot.com partselect.com apwagner.com repairclinic.com Thank you for using Fixya.Com,if you should require further assistance please reply and i will be happy to help,GENE
All lights and ignitors on my GE ZGU385N (Gas
Disconnect power and set you meter to ohms. Check the both the line side and the low side of the the ****** for continuity. If you cannot get a reading from either side then that puppy is bad. More than likely that is gonna be it since everything quit. If it was the igniter box you might have weak spark etc. I thnk that transformer is your prob. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
