20 Most Recent
Crosley CE35111AA Electric Kitchen Range Questions & Answers
Appliances Houston
We sell NEW overstock and scratch & dent appliances which come directly from Whirlpool. From ovens to refrigerators, microwaves to washers and dryers, stoves and dishwashers-all your home appliance needs for less than EVERYONE ELSE!
Solocenter.com
I can't find a button
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps!
9/20/2015 6:53:05 PM •
Crosley...
Answered
on Sep 20, 2015
My crosley self cleaning oven door is locked and i can't open it
I don't know if this will help, but try unplugging the stove from the back of the electrical outlet to the wall, wait for a minute or so, then plug back in and see if this works. I know with other similar problems of this nature, it has worked. Can't loose without trying.
K.E.
5/21/2015 3:46:38 AM •
Crosley...
Answered
on May 21, 2015
It's flashing F3 and I can't get it to reset.
Hello & Welcome to FixYa
F3 error means a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
2/3/2011 8:11:38 PM •
Crosley...
Answered
on Feb 03, 2011
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
Hope that helps! RC
10/17/2010 9:35:32 PM •
Crosley...
Answered
on Oct 17, 2010
I have a kitchenaid ceramic
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
1/1/2009 2:55:36 AM •
Crosley...
Answered
on Jan 01, 2009
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
5/5/2008 10:09:23 PM •
Crosley...
Answered
on May 05, 2008
