20 Most Recent
Nikon COOLPIX L18 Digital Camera Questions & Answers
I have continuously had battery problems with my
Recharables as it will be cheaper since these are huge battery eaters NIkon is keeping the battery companies in business with you folks. BY all means find a diffrent brand you not the only ones with battery eaters!! Canon SLR, Pentax are the best battery savors in town. Quit feeding the energiser bunny and move on to better cameras is my recomendation and expert advice to you! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Black Screen
Do more internet searches of your model. Sounds like the sensor chip died. Pretty expensive part. Could have not liked the salty environment or you are just unlucky. Do the search until you give up as there is a lot of info on internet. Cameras are getting pretty cheap now so if it is a little old or cheaper model, you may do better with a forced "upgrade".
Lens locked out position wont close
try taking out the battery and re;install.lens should retract.if not,switch off camera and very GENTLY try to push in lens,while camera is still shutting down.otherwise have it checked by expert.
Battery compartment won't open?
Push the cover toward the back of the camera and then toward the end, just as the arrow indicates, then the end of the cover nearest the end of the camera will swing open. Follow the illustration in the "Insert the Batteries" section of the manual (page 12 in my copy).
What is write protected
It probably refers to intellectual property protection i.e. copyright, trademark, patent etc.
How do I delete all pictures from my Coolpix L 18
Is there not a button with an icon of a bin next to it on your camera?
You could also just hook your camera up to a computer, browse to the folder, select all the pictures and delete them like that.
Prongs inside mini usb port on camera nikon d40 bent
best thing to do is send it in for repairs but if your confident in opening it up then just make sure you take note of exactly how you opened up so you are able to put it back together again and then carefully bend the pins straight or how ever they were originally remember if over bent you run the risk of snapping the pins and then you will have to (and this is not often very easy to do)source the unit and then have the skills of soldering and this is also not very easy
How to bring up photos on my computer from camera.
you will need the usb cable to connect your camera to your pc and when you connect them the software should install either automatically or if the camera came with a cd you will need to insert the cd and install the software yourself then when you open the program that was installed it should give you an option to view the photos or to sync them with the pc and if this is not the case when you connect the camera if you open my computer there should be another drive where you see your C: drive
Why does the date/time on my L18 keep changing itself
This indicates that the built-in battery of the camera is damaged.(All digital cameras have a tiny built-in battery)
Replace that battery and you'll be OK. Don't ask me how to do that change. Get the manufacturer to point you to the location of that built-in battery or put it to a service centre.
