20 Most Recent Adobe Acrobat 7.0 Professional Questions & Answers
3answers
Suddenly all my pdf docs are opening in Adobe
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
8/16/2022 12:11:35 PM • Adobe Acrobat... • Answered on Aug 16, 2022
2answers
How do I remove a watermark in Adobe 7?
go to insert->picture->impression check on remove watermark option
7/1/2022 3:49:24 AM • Adobe Acrobat... • Answered on Jul 01, 2022
2answers
Serial number for Adobe Acrobat 7.0 Professional
This is the serial number for Adobe Acrobat 7.0 professional: 1118-0211-6703-7799-4253-9326
8/12/2021 5:01:45 AM • Adobe Acrobat... • Answered on Aug 12, 2021
4answers
How do i remove a watermark in 7.0 when undo will
Here is the procedure for Acrobat 8.
To remove all watermarks from all pages, choose Document > Watermark > Remove, and click OK to confirm the removal.
7/1/2021 5:57:01 AM • Adobe Acrobat... • Answered on Jul 01, 2021
3answers
Repair damaged pdf
See this theme on non-commercial resource: http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/417-%E2%80%8Bdamaged-pdf-file-cannot-open Guide for PDFTK (Freeware) 1)Download Gui for PDFTK from the Paehl website. 2)Double-click the downloaded installer to begin the program's setup. 3)Click "Start," select "All Programs" and click "Gui for PDFTK" to open the program. 4)Click the "..." button next to "PDF file" and locate your corrupt PDF. Click the "..." next to "Target" if you are not happy with the output file name. 5)Click "Repair a PDF." Wait for Gui for PDFTK to confirm repairing is complete. 6)Close Gui for PDFTK. Your repaired PDF will be in the same location as the original PDF unless specified otherwise. To read more about them pdf repair service online, visit: https://onlinefilerepair.com
3/12/2021 5:23:16 AM • Adobe Acrobat... • Answered on Mar 12, 2021
tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
3answers
My serial number is 1118
my serial number is 1118 - 1219 - 3189 - 4054 - 0424 - 2579 please send me the authorization code
2/9/2019 12:14:28 PM • Adobe Acrobat... • Answered on Feb 09, 2019
11answers
How can i edit in pdf files
If you are having a hard time using the Adobe Acrobat, you can try an easier program which is the LightPDF. This program doesn't need any installation or software download. Try this program here: https://lightpdf.com/
7/2/2018 2:19:03 PM • Adobe Acrobat... • Answered on Jul 02, 2018
How to install tamil font in adobe acrobat
Hi The below link may help you . Hope it helps . https://helpx.adobe.com/acrobat/using/pdf-fonts.html
6/7/2018 10:07:37 AM • Adobe Acrobat... • Answered on Jun 07, 2018
I have Adobe Acrobat 7.0 Professional, I can not
It depends what program made the file. Let's say you made a file in Microsoft Word. You should be able to go to file:print, then when the printer comes up, select PDF instead of the printer. I know this bypasses your Adobe, but it is a way to make a PDF. But, it sounds like the path to your Adobe program might not be right. On your start menu, right click on Adobe and select "Open file location". This should take you to the Adobe exe file that starts your program. If not, you need to find your Adobe folder, and make a new shortcut to Adobe by dragging (right click and hold) to your desktop.
11/5/2017 12:17:17 AM • Adobe Acrobat... • Answered on Nov 05, 2017
2answers
I am facing problem in downloding PDF files from
What problem are you facing?
Downloading PDF files is no different from downloading other files.
Of course, you'll need Adobe Reader (or something similar) to be able to "view" the PDF file, after you have downloaded it. Access: http://www.adobe.com to access the download Adobe Reader 9.3 for Windows.
9/29/2017 7:56:42 PM • Adobe Acrobat... • Answered on Sep 29, 2017
Adobe Acrobat 7.0 Professional authorization code
Hi go to http://www.adobe.com/downloads/cs2_downloads/Download the product and Serial Number is available with the Download ... Uninstall the old software from the system ... Enjoy ....
6/21/2017 4:22:11 AM • Adobe Acrobat... • Answered on Jun 21, 2017
Delete a Line Space
you may have to enable edit feature in the pdf form to make changes
6/15/2017 9:55:31 AM • Adobe Acrobat... • Answered on Jun 15, 2017
Acrobat 7 Pro - combining multiple pdf to single pdf errors
https://acrobat.adobe.com/in/en/acrobat/how-to/merge-combine-pdf-files-online.html
3/16/2017 8:00:53 AM • Adobe Acrobat... • Answered on Mar 16, 2017
2answers
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.Go to the Click here for the Link to Download AcrobatDownload the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
10/19/2015 2:27:30 PM • Adobe Acrobat... • Answered on Oct 19, 2015
Highlighting a graphic or scanned text in pdf file
If the text is editable you can use the TouchUp Text Tool.
For images use the TouchUp images tool.
Both are located in the Tools Pallet under Advanced Editing.
10/17/2015 4:06:10 AM • Adobe Acrobat... • Answered on Oct 17, 2015
3answers
Adobe Acrobat 8 Serial number!!
Hi
I found a keygen for you :
http://rapidshare.com/files/53395198/Acrobat_8_keygen___Activation.exe
how to use:
Download the keygen from the link then open it and open adobe acrobat 8 then press generate serial number and copy it to adobe acrobat ,it will say it's not valid or somthing like that so you press activate by phone , it gives you an activation number so copy it and paste it in the response box in the keygen and then press generate activation key ,open adobe acrobat again and copy the key to it , it should work i think
best wishes :]
12/5/2014 1:26:54 AM • Adobe Acrobat... • Answered on Dec 05, 2014
Adobe Acrobat 7.0 Professional Logo
404 questions posted
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adobe Computers & Internet
Most Popular Question
repair damaged pdf
  • Computers & Internet
