20 Most Recent Craig CMP741d Tablet Questions & Answers
Forgot login for Craig 7" Android tablet
how do i do a hard reset on a craig cmp741d 7-in touchscreen 4.0 android tablet
1/14/2020 3:10:18 AM • Craig CMP741d... • Answered on Jan 14, 2020
2answers
Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections6. Use the volume buttons to move up and down through selection in this menu7. Using the volume down button, scroll down to "Wipe data/factory reset"8. Tap Power hard key to select option9. Scroll down to select "Yes, delete all user data"10. Tap the power button to select. Wiping and formatting data will take a few minutes.11. You will return back to the Android recovery screen menu.12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
1/12/2020 5:51:14 AM • Craig CMP741d... • Answered on Jan 12, 2020
2answers
How do i unlock my tablet after ive entered too many pattern attempts, and have forgotten my Username(email) Password?
its brand new and you forgot everything already if you did the google mail password assist then open that if dont know that or didnt do it can try provider for assistance and most lockouts are either 1hr or 24hr
12/23/2018 9:52:56 AM • Craig CMP741d... • Answered on Dec 23, 2018
How to install google play
The Google Play is pre-installed in all Android Phones and Tablets. If it is not pre-installed it's either not Android or check the Google Play Website and try to download any App after registering a Free Account :https://play.google.com/store
4/3/2017 2:25:31 AM • Craig CMP741d... • Answered on Apr 03, 2017
My craig tablet has a white screen and will not
You'll need to do a factory reset:1. With the device off, press and hold Volume Up and Power.2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.4. Press Volume Up continue.
9/23/2016 3:28:04 AM • Craig CMP741d... • Answered on Sep 23, 2016
2answers
Cannot download apps
tablet cannot download apps
7/2/2016 5:36:48 AM • Craig CMP741d... • Answered on Jul 02, 2016
My sons friend changed his password and everytime I go to reset it it just turns off. How do I reset?
  • First, switch your tablet off.
•Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. • Continue holding the volume button until the screen says "Booting tablet in recovery mode." • This will give you a picture of an Android. •Tap the android, and you will be given a screen with several options. •Move between the options with the + and -, and select with the power button. •Go to the option for Factory Data Reset and select it. •Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. •Once it has completed, select Reboot Tablet Normally.
8/29/2015 8:17:30 PM • Craig CMP741d... • Answered on Aug 29, 2015
Authentication problem
trying dumbing down the authentication on your wifi router. Try these: turn off 40mhz wide channels try wpa instead of wpa2 try tkip instead of aes if all else fails, try wep.
6/19/2015 12:32:18 PM • Craig CMP741d... • Answered on Jun 19, 2015
2answers
My tablet is froze when i bought it it already had a password on it how can i fix it
You need to restore the Operating System.
3/14/2015 11:01:02 AM • Craig CMP741d... • Answered on Mar 14, 2015
When connected to charger red lights keeps flashing but tablet wont charge or switch on
Your dc socket is probably on its way out- soon it wont connect charge at all-bad future outlook on this- return if possible.
3/10/2015 9:16:03 PM • Craig CMP741d... • Answered on Mar 10, 2015
Cant turn on my Craig Android Tablet...
Is it charged, does it charge properly? It may just be dead.
2/16/2015 1:22:32 AM • Craig CMP741d... • Answered on Feb 16, 2015
Craig CMP741d Tablet Logo
423 questions posted
Top Craig Tablets & eReaders Experts
john h
 Mikey
Mikey
Larry Ng
Larry Ng
Are you a Craig Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Craig Tablets & eReaders
Most Popular Question
unlock tablet after ive entered many
  • Tablets & eReaders
