20 Most Recent
Casio fx-115ES Plus Scientific Calculator Questions & Answers
How do i get the ee to work on my casio fx-115es plus?
What you call the EE ((entering power of 10 exponents) is done with the help of the key at the bottom right, and marked [
x10^X].
To enter 6.02x10^23, you do as follows
6.02 [
x10^X]23. When you use that short-cut key, no 10 should appear on the command line. See screen capture.
Fix scientific calculator
Increase the contrast. Press [SHIFT][MODE] to enter the SETUP. Use the down arrow to locate the contrast option. Use the Right arrow to increase the contrast.
How to get l1 l2 l3 charts
L1, L2, L3?If you are doing statistics, Set MODE to 3. Stat.Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.For any regression model you have 3 lists x, y, and Freq(uency).L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.I hope it helps
How do i get l1 l2 l3 charts up
L1, L2, L3?If you are doing statistics, Set MODE to 3. Stat.Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.For any regression model you have 3 lists x, y, and Freq(uency).L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.However I have no idea what getting the charts up mean.I hope it helps
Inverse log function
For the common antilog, use the 10^x function available as the shifted function of the log key. For example, to calculate the common antilog of 2, press SHIFT log 2 =If you want the natural (base-e) antilog, use e^x available as the shifted function of the ln key.
