How to get into the cave and find romanos
try this and see if it helps. Let me know one way or another.
Now, time to enter the cave. Woot, time for your first dungeon, sub-dunegeon,
I guess, but still. Walk through the narrow passage, and pick up and toss the
three boulders blocking your path.
Continue on. You'll notice a locked door, which you need a key for. If you
continue on, a bunch of red chus drop to the ground. Attack them, and open
the chest. A small key! Go back to the door, and open it.
Advance and defeat the chus that appear. You'll notice four levers. In order
to open the door, you have to pull them in a certain order. Although you're
SUPPOSED to get clues, it's a guide, and here's the order.
2 1 DOOR 4 3
A key will drop if you did it right. Now you could go on, but if you want some
extra rupees, follow the next paragraph.
Go to the left, pushing the block. To do that - tap the block, and touch the
direction you want to go. Do it two or three times, and then attack the bats
for somem money.
Now, go to the right. Push the block the same way as the left entrance. There
is a bunch more bats, so unleash a few spin attacks, and smash the pots. Now,
open the treasure chest for a red rupee! NOW, you can go back and open the
door.
Now, go to the next floor up the stairs, and then slash the three or four
rats. One's roaming around with a key. He's running in and out of rat holes,
so you need to outsmart it. Maneuver the block in front of the rat hole, on
the left side.
Now, stay outside of the wings, and wait for it to go to the next hole that
you just blocked. It will then turn around and dash towards the open one. In
that time, run infront of it's path and slash it. If you missed, repeat. Go
back, and open the door.
Run through the passage - smashing the final boulders and defeating the final
enemies. Now, run down through the exit.
