20 Most Recent Jenn-Air JennAir 1.5 Cu. Ft. 30 Built In Microwave Questions & Answers
Jennaire Microwave JMV9196CS-3 Book says the grease filter is on the bottom of the oven.There are two lights covered by a glass panel. How do I get to the grease filter?
The grease filter is in the center between the lights. See the interior and ventilation diagram available here: https://www.searspartsdirect.com/model-number/jmv9196cs3/1266/0123370.html . However, you might have this: https://www.partselect.com/Models/JMV9196CS3/Sections/04-Interior-And-Ventilation-Parts/?ModelID=7548870&ModelNum=JMV9196CS3&mfgModelNum=&ManufactureID=1&Selected=0794E2BFBF59CB9582BAA592BE0124B3C5F48AE9.gif&Position=4&mfg=Maytag&Type=&Mark=4 . The base (33) is secured by the door hinge (part 32). I'd suggest you try pushing up on the sides of the base and seeing if it will then rotate down. Unfortunately, I don't see any details about Jennaire microwaves with this type of base. I hope this helps. Cindy Wells
1/8/2019 3:56:38 PM • Jenn-Air JennAir... • Answered on Jan 08, 2019
Jenn-Air JMV9186WS Microwave. I was replacing the vent grill and touched something behind the white cam that rotates when microwave is on and it blew. It has no power now. What could be done?
Question edited for clarity. Question moved from Laundry Dryers. Check the circuit breaker or if it has a 13 amp UK plug, check the fuse inside the plug. There may be a fuse on the the control board, but getting to it is not safe. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
3/19/2023 10:56:04 PM • Jenn-Air... • Answered on Mar 19, 2023
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
Hi Doug, Did you ever figure out how to replace the light bulb in the microwave? I have the same problem and can't get to the bulb. My email is [email protected] you have any info to help. Thanks.
12/12/2020 2:52:05 PM • Jenn-Air... • Answered on Dec 12, 2020
Jenn-Air M170 Microwave Oven "dimensions
http://kitchen.manualsonline.com/manuals/mfg/jennair/m170.html Toll free 800 number and email for support. https://www.justanswer.com/appliance/6r6z4-dimensions-jenn-air-m170-built-in-microwave.html Link above states: What are the dimensions of the Jenn-Air M170 built-in Microwave... What are the dimensions of the Jenn-Air M170 built-in Microwave Oven (built 1998) that I need to specify for a replacement unit? Externally, I see the frame measuring 26 3/4" W by 17" H, and the unit within the frame measuring 22" W by 13" H. Share this conversation Answered in 1 hour by: 6/5/2012 Appliance Technician: Ed Michaels Ed Michaels : Hi, your machine is long out of production and installation instructions usually come with the machine and are not published. you have a standard size 24" built in machine, and most 24" machines will fit the space. I would click on Jenn Air or call 1-800-JENN-AIR (536-6247) and ask for a replacement recommendation and a copy of old installation instructions for planning with designer or installer. They have access to records if anyone does and an interest in serving you. Alternatively, talk to another seller and discuss installation. they will also want to help. Let me know if I can help further.ed
3/9/2018 1:59:14 AM • Jenn-Air... • Answered on Mar 09, 2018
I am installing a Jenn-Air Wall Oven and Microwave Combination. The problem is electrical. The electrical cable in my wall has 3 wires: a black, a white, and an unshielded ground. The oven/mircrowa
Do you have the installation instructions that came with the oven? An electric oven requires a 220V circuit and the cable coming out of the wall you described is a 110 V circuit.
11/27/2017 6:17:14 PM • Jenn-Air... • Answered on Nov 27, 2017
I have a Jenn-Air JMV9169BAS microwave that doesn't heat. I looked at other similar posts and have checked the capacitor and replaced the magnetron. I can't get the diode out to check it. I don't smel
It's really not safe to measure the voltage while it's running unless you truly have training and experience. The risk is not "radiation," but instead the high voltage (4000VAC) and its frequency, which can be instantly lethal. Microwave ovens do not contain or produce ionizing radiation as found in atomic or nuclear energy. That is just a common myth. Microwave energy is much like radio waves or light, and while it can cause burns, you'd likely pull away due to heat before much if any damage were done. The service manual (with installation instructions) is here: http://www.microwavecontrol.com/AMV1154_AMV5164_AMV5206_AMV6167_JMV8166_JMV8208_JMV9169_MMV1153_MMV4205_MMV5165_MMV5207_UMV1152_inst_sm.pdf When a high-voltage rectifier diode fails, it almost always shorts, which will result in a growling / groaning sound when trying to cook, but no heat. Ideally, this test should be performed on a high-voltage diode: 9v_battery_meter_test_hv_diode-bamrfjjfhaycgefspgj211on-2-0.jpg A good parts source is the Pros here. - William E. Miller, AS-EET [email protected] http://www.microwavecontrol.com Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
5/6/2017 11:16:01 PM • Jenn-Air... • Answered on May 06, 2017
I have Jenn-Air cooktop with
Something is shorted out. Leave the breaker off until you find it. You need an ohmmeter to find it, but look for the black marks for a hint.
4/6/2017 3:34:59 PM • Jenn-Air... • Answered on Apr 06, 2017
W2400 jenn air microwave door latch broken door will not open
If you wish to get some details about microwave oven; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
7/17/2016 2:53:56 PM • Jenn-Air... • Answered on Jul 17, 2016
Jenn-Air jmc2430 built-in does not run.
Hey David... sorry to say There's a $14 fuse between cooking & your magnetron (could be other things (but in my opinion... magnetrons sound right for your symptoms) I checked for your magnetron and got MFR Number 461967847321 - not AVAILABLE. (there is one $74 on eBay (very bottom, below)). I LOOKED at your oven and it is a really nice one... So I think I'd be hitting all the on-line parts houses to see if you can locate one... Jenn Air jmc2430 built in does not run http://www.appliancepartspros.com/whirlpool-magnetron-461967847321-ap5987313.html 461967847321 NEW MAGNETRON WHIRLPOOL KITCHENAID MICROWAVE NON OEM WITH...
5/15/2016 3:24:38 PM • Jenn-Air... • Answered on May 15, 2016
How do i replace the light bulb in a maytag UMC5200BAS wall mount?
Hi, The only way is too remove the cover to the microwave. Part number WP4713-001012. If you have never entered into a microwave you may want someone to do this for you. Safety first!! Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4/16/2016 12:49:29 AM • Jenn-Air... • Answered on Apr 16, 2016
Jenn-Air Microwave (Model Number : jmv8208bas) sparking
If you wish to get some details; check the site linked here. Pull up older posts..... http://electro-medical.blogspot.com/
4/10/2016 7:25:43 PM • Jenn-Air... • Answered on Apr 10, 2016
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
4/2/2016 11:21:37 PM • Jenn-Air... • Answered on Apr 02, 2016
0answers
Jenn-Air JennAir 1.5 Cu. Ft. 30 Built In Microwave Logo
2 questions posted
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Microwave Ovens
Most Popular Question
jennaire microwave jmv9196cs 3 book says
  • Microwave Ovens
