20 Most Recent Randell 2020F Reach-In Freezer, 2-section, self-contained refrigera" Questions & Answers
2answers
My freezer is flashing P2 - what does this mean?
Well, no, actually. P2 is an error related to the evaporator temperature probe. I would start with the electrical connections, the bond between the probe and the evaporator, and the evaporator fan.
7/12/2020 4:48:30 PM • Randell 2020F... • Answered on Jul 12, 2020
0answers
Freezer is too hot and
Either the freezer needs to be defrosted or it went into defrost and didnt come out. So most likely your defrost system has failed. A good way to check this will be to unplug freezer for about a day or 2, and let it defrost manually. Should begin working properlt again when plugged back in . The problem will return suggesting your defrosy system has failed.
What is the make and mod of the freezer so i can tell you how to access it.
2/20/2011 11:03:39 AM • Randell Freezers • Answered on Feb 20, 2011
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
2answers
Norfrost c6aew chest freezer compressor wiring
Hey. I dont suppose you figured out where the wires went all all? I've done the same thing ???? img-20240210-wa0019-hnmqxmichaytgjvoydy3hl3m-d-0.jpg img-20240210-wa0018-hnmqxmichaytgjvoydy3hl3m-d-1.jpg img-20240210-wa0020-hnmqxmichaytgjvoydy3hl3m-d-2.jpg
2/11/2024 12:01:33 PM • Freezers • Answered on Feb 11, 2024
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words. That is an overheating fault. Replace the fluff with no fluff. Make sure the condenser coils are free of dust and there is good airflow Or It is low on refrigerant gas and you need a service tech.. ..
2/3/2024 5:25:13 AM • Freezers • Answered on Feb 03, 2024
Cubic feet of a fridgeadare chest freezer- FFC13K2CW1
The Frigidaire FFC13K2CW1 chest freezer has a capacity of 12.8 cubic feet. More info: https://www.partselect.com/Models/FFC13K2CW1/
1/22/2024 2:51:52 PM • Freezers • Answered on Jan 22, 2024
One of the drawers in my upright freezer BRADA MF-305 broke. Is it possible to replace it please?
Question edited for clarity. Duplicate question deleted. Refresh page to see you question. This is not a make I know. Things like drawers are usually readily available. This link may work better where you are located. https://www.google.com/search?q=BRADA+MF-305+parts Generic Drawer replacements https://www.google.ca/search?q=freezer+drawer+replacement&sca_esv=580628691&tbm=isch&sxsrf=AM9HkKk2I1HuWqUimTZskQkh3tRH3AJ6rA:1699481832834&source=lnms&sa=X&ved=2ahUKEwiZ0MqXt7WCAxUwL1kFHUrtBG0Q_AUoAnoECAIQBA&biw=1920&bih=919&dpr=1 ..
11/8/2023 10:18:51 PM • Freezers • Answered on Nov 08, 2023
My chest freezer will not freeze food on top layer or in basket
Is it on Economy Mode? That only chills the bottom area. Check the condenser fins are cleaned of dust. That needs doing every 6 months. Or it needs refrigerant gas. ..
10/5/2023 3:35:25 AM • Freezers • Answered on Oct 05, 2023
I would like to know when will Walmart Canada online have the Arctic King 7.0 Chest Freezer E-Star back in stock?
Question edited for clarity. Question moved from Star Computers. Greetings from Toronto! It is made by Midea and sold to Walmart as a batch, "make us 10,000 at $100 each. We will sell for $280 until they are gone". All the retailers are out of stock including Amazon and Wilson's Home Store. Choose another make and model, bottom of this page. Home Depot, Leon's or The Brick are a good bet for Freezers. https://www.dontwasteyourmoney.com/products/arctic-king-arc070s0arbb-7-cubic-feet-chest-deep-freezer/
8/18/2023 11:46:21 PM • Freezers • Answered on Aug 18, 2023
2answers
There is water accumulated in my Norfrost Aura chest freezer. How do I drain it?
There is normally a drain plug on the lower rear or sides. You probably have leaking door gasket. https://www.google.com/search?q=norfrost+aura+chest+freezer+drain+hole+location ..
8/18/2023 7:11:29 AM • Freezers • Answered on Aug 18, 2023
2answers
My freezer makes a very loud noise when I turn it on.
There appears to have been a serious electrical problem in the freezer, possibly involving a short circuit or a broken part.it's best to contact a professional appliance repair technician
8/18/2023 7:10:20 AM • Freezers • Answered on Aug 18, 2023
I have a Traulsen 31300 6 half door freezer that cools down to 28F but won't go below.
If your Traulsen 31300 freezer is cooling down to 28°F but not going below that temperature, and the compressor runs continuously except during the defrost cycle, there are a few tests you can perform to help diagnose the issue before considering replacing the expansion valve. Here are some steps to follow: 1. Check Airflow: Ensure that the airflow inside the freezer is not obstructed by any items or ice buildup. Verify that the evaporator coil is clean and not blocked. Poor airflow can lead to inadequate cooling. 2. Temperature Control Setting: Confirm that the temperature control setting on the freezer is correctly set to the desired temperature. Make sure it is not accidentally set too high or too low. 3. Condenser Coil Cleaning: Clean the condenser coils located either at the back or underneath the unit. Dust and debris accumulation on the coils can reduce cooling efficiency. Use a soft brush or vacuum cleaner to remove any dirt or debris. 4. Condenser Fan Operation: Check if the condenser fan is running properly. The condenser fan helps dissipate heat from the system. Ensure it is spinning freely and not obstructed. If it's not working, it may need to be replaced. 5. Check for Refrigerant Leaks: Perform a thorough inspection of the refrigerant lines and connections for any signs of leaks, such as oil spots, bubbles, or hissing sounds. If a refrigerant leak is suspected, it could be affecting the cooling performance, and repairing the leak and recharging the system may be necessary. 6. Pressure and Temperature Readings: To determine if the expansion valve is the culprit, you may need to take pressure and temperature readings at different points in the refrigeration system using specialized equipment. These readings can help identify any irregularities or inefficiencies in the system. 7. Consult with a Professional: If you're unsure about performing these tests or interpreting the results, it is recommended to seek assistance from a professional refrigeration technician. They will have the expertise and necessary tools to accurately diagnose the issue and provide appropriate solutions. By conducting these tests and inspections, you can gather more information to make an informed decision about replacing the expansion valve or pursuing other potential causes for the inadequate cooling.
6/21/2023 2:35:28 PM • Freezers • Answered on Jun 21, 2023
How to unlock freezer lock c722
All questions need 'make model (what is is)' as first 3 words. Taylor Ice Cream maker? https://www.google.com/search?q=unlock+freezer+lock+c722 ..
4/22/2023 4:59:24 AM • Freezers • Answered on Apr 22, 2023
Randell 2020F Reach-In Freezer, 2-section, self-contained refrigera" Logo
1 questions posted
Top Randell Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Randell Freezer Expert? Answer questions, earn points and help others
View Most Popular
Randell Freezers
  • Randell Freezers
Most Popular Question
freezer flashing p2 mean
  • Freezers
