20 Most Recent Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack Questions & Answers
Manual for K P 028
Google
Manual for K P 028 it should give you everything you are looking for.
1/18/2019 12:35:44 AM • Duracell Crank... • Answered on Jan 18, 2019
0answers
Usb
Be the first to answer 6/7/2013 3:45:05 AM • Duracell Crank... • Posted on Jun 07, 2013Be the first to answer
0answers
Owner's manual
Be the first to answer 11/29/2012 10:38:21 AM • Duracell Crank... • Posted on Nov 29, 2012Be the first to answer
Model: KP028 It doesn't work no matter how long I
the batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
7/22/2011 5:14:16 AM • Duracell Crank... • Answered on Jul 22, 2011
My duracell crank light 3 in 1 is not working properly
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
3/20/2011 9:24:11 PM • Duracell Crank... • Answered on Mar 20, 2011
Need battery charger
Bought a universal charger from Radio Shack with plug that match spotlite.
6/24/2009 2:08:08 PM • Duracell Crank... • Answered on Jun 24, 2009
Need owner's manual
e548fa9.jpgafae0af.jpg3e075ea.jpg4392de5.jpg Max is 150K so sorry for bad quality.
5/18/2009 6:03:43 AM • Duracell Crank... • Answered on May 18, 2009
Need an instruction and repair manual for a Duracell KP028 flashlight/radio.
Duracell KP028 not found on Duracell website. User Manuals ' DURACELL FLASHLIGHTS You can request the user manual from company directly using the contact form. DURACELL FLASHLIGHTS You can use this manual for help SOLVED: Need owner's manual - Fixya
2/5/2024 11:43:16 AM • Duracell... • Answered on Feb 05, 2024
I have replaced the batteries in 2 duracell 350 flashlights but I can't make them turn on.
the bulbs could be bad, the batteries could be bad, you could have replaced with incompatible batteries or have the wrong orientation. did you realign the compartment to make contact ? often the spot where the batteries go have a wire or metal that connects to another wire or metal when you replace the battery compartment- maybe that metal or wire is not aligned correctly or touching like it should. This was not a question but more of a generalized problem that could have so many solutions. Im not sure more information would have. good luck https://www.6ya.com/mrmmike
3/2/2019 9:18:17 PM • Duracell... • Answered on Mar 02, 2019
Duracell flashlight only blinks when push off on button
Have you tried holding the on button for a few seconds or switching it on/off/on quickly?
2/5/2018 4:24:28 AM • Duracell... • Answered on Feb 05, 2018
0answers
Warranty on corrosion of battery & damage to light
if this all the info i can i will
just through the damm light in the garbage
have a nice day thank you
2/20/2009 3:12:42 PM • Duracell... • Answered on Feb 20, 2009
Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack Logo
9 questions posted
Top Duracell Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Duracell Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Duracell Camping, Backpacking & Hiking
Most Popular Question
model kp028 doesnt work no matter long
  • Camping, Backpacking & Hiking
