20 Most Recent
Vector 2M Pwr Rch Spotlight Questions & Answers
I simply need to know what the 3 colored LEDs on
Red, Yellow, Green are the battery level indicators, Red being the lowest like a fuel gauge. If the green comes on right away after plugging in the charger then it must not indicate the charge cycle. If its a 3Ah battery whats the charger output amperage? Then you could just do the math to figure out how long it would take to charge that battery to full with the output. Otherwise it shouldn't hurt it to leave it plugged in overnight or at least a few hours to charge it.
Hi there!, I need to replaced a stanley 2M
I found a 2.9 amp which seems to be the only replacement available. It fits although the dimensions are Length 3.11 - Width 2.1 Height 4.21 The model # is PS-1227 and is available at batterybuyer.com
I have a Vector 2,000,000
There is good news and bad news concerning a replacement battery for this particular model light.
The good news is that a suitable, but not exact, replacement will be available at Battery Mart on November 30, 2010.
The bad news is that it cost $29.95.
http://www.batterymart.com/p-sla-1039-12-volt-2-3-ah-sealed-lead-acid-battery.html
I purchased about a dozen of these lights in 2006 and have had them in storage since. No one can or will be more unhappy than I should all of them need new batteries.
Trileaf distribution trifeuil
Check and replace the bulb. Make sure your charger has power coming out of it. Also, depending on how long you have owned this the battery could be shot. Just as cheap to buy a new light as it is to buy a new battery.
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
INCLUDES AC AND DC CHARGING ADAPTERS
INCLUDES BUILT IN HANDS FREE WORKSTAND
