20 Most Recent
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Questions & Answers
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
MKAC2194971
Check EBay. I see prices ranging from $100 to $180.
