20 Most Recent
Maytag Centennial MVWC300VW 3.2 Cu. Ft. Top Load Washer - White Questions & Answers
My washer is making a card stuck in bicycle spoke sound during rinse/spin cycle
Something has probably got behind the drum. Usual suspects are broken underwires from bras and hair clips or pins.
Spin it by hand when empty, both ways and see if you can figure out where it is at. Check the filter and the flexible rubber hoses from the drum drain point to the filter and the filter to the pump. Give those hoses a squeeze and see if you can feel anything in them. I have found bits of underwire, coins and small metal items. They are removable with a bit of effort, but be prepared for water spillage. Take a photo before you remove anything so you can see how it all fits back together.
2/3/2016 5:19:00 PM •
Maytag...
Answered
on Feb 03, 2016
Maytag MVW7232HW0 top load, error codes and condensation on control panel when using hot watet
1. ERROR CODES: CHECK THE USER MANUAL FOR THE WASHER TO IDENTIFY THE SPECIFIC ERROR CODES BEING DISPLAYED. THIS WILL HELP YOU PINPOINT THE ISSUE AND TAKE APPROPRIATE ACTION, SUCH AS RESETING THE WASHER OR CONTACTING CUSTOMER SUPPORT.
2. CONDENSATION ON CONTROL PANEL: IF YOU'RE EXPERIENCING CONDENSATION ON THE CONTROL PANEL, IT COULD BE DUE TO THE HOT WATER TEMPERATURE OR THE HUMIDITY LEVEL IN THE ROOM. TRY USING WARM WATER INSTEAD OF HOT WATER TO SEE IF THAT REDUCES THE CONDENSATION. YOU CAN ALSO TRY INCREASING VENTILATION IN THE ROOM TO HELP DISPERSE THE MOISTURE.
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
Maytag LSE1000 Got the top off the machine but can't move top off because of all the attached wires. Is the only way to remove wires?
es, in order to remove the top of a Maytag LSE1000 washing machine, you'll need to first disconnect any attached wires. This is because the wires are connecting important components like the control panel and the sensors to the rest of the machine.
Here are the steps you can follow to safely disconnect the wires:
- Unplug the washing machine: Before you begin, make sure to unplug the machine from the power source to prevent any electrical shock.
- Locate the wires: Look for the wires that are connecting the top of the machine to the rest of the machine. They should be near the back of the machine where the top and bottom halves of the machine meet.
- Label the wires: Label the wires so you know which wire goes where when you're ready to put the machine back together. You can use masking tape and a marker to label each wire.
- Disconnect the wires: Gently pull the wires from their connectors, making sure to keep them separated so they don't get tangled. Be careful not to pull too hard, as this could damage the wires or the connectors.
- Repeat the process for all the wires: Repeat the process for each wire until they're all disconnected.
Once you've disconnected all the wires, you should be able to remove the top of the machine. Make sure to keep the wires organized and in a safe place while you're working on the machine. When you're ready to reassemble the machine, simply reconnect the wires in the reverse order you disconnected them.
