20 Most Recent
Samsung WA456DRHD 27" Top-Load Washer with 3.86 cu. ft. Capacity, 11 Wash Cycles, 6 Options, 5 Temperature Settings, AquaJet Cleaning Technology, Smart Care and Diamond Drum Questions & Answers
Add garment light won't go off when Samsung front loader locks. Stops cycle from beginning - Samsung front loader model #WF42H5000AW/A2
Check the Door Latch and Alignment:
Ensure that the door is completely shut and latched. Sometimes, clothing or debris can get caught between the door and the latch, preventing proper closure. Make sure there's nothing obstructing the door.
Inspect the door seal for any damages. A damaged seal might not allow the door to close securely.
Child Lock Feature:
Samsung washers come with a child lock safety feature. If the child lock is engaged, it prevents accidental start of the wash cycle.
Check if the child lock is activated. If so, disable it and try running the wash cycle again.
Motor Control Unit (MCU) Inspection:
Visually inspect the Motor Control Unit (MCU) board for any burned spots. The MCU is located on the left side behind the lower access panel.
If you find burnt spots on the MCU, it might be the cause of the issue. You can order a replacement MCU if needed.
Other Troubleshooting Steps:
Reset the washing machine by unplugging it and then plugging it back in after a few minutes.
If the problem persists, consult a technician to inspect the lock mechanism or control board.
Drain pipe clogged in samsung sr606-ev - how to clean it/ unclogged?
Is this the flexible pipe coming out of the back of the machine or the pipe work inside the machine? The flexible pipe (usually grey in colour) is a 'push on' fit. You'll need to get in behind the machine. With a bit of wiggling and twisting the pipe should pull off at the machine end. You should then be able to get the whole thing out from behind the machine to clean it. I used an long, old piece of wood dowel to loosen the dirt. I then carefully flushed it through using a garden hose with the nozzle set to jet, not to the wide spray pattern. I know this because I got very wet making that mistake.
