20 Most Recent
Airpura T600 Tobacco Smoke Filtration Air Purifier Questions & Answers
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
Should I color my hair purple?
The Purple color that you will colored is amazing.Angel Brazilian Virgin Hair Online Store will supply you high quality hair with best price. The hair extension you can buy in our store in purple color.that color is good.A Brazilian weave, also referred to as a Brazilian wave, utilizes 100-percent virgin Brazilian hair to create a soft, wavy style. A stylist can apply Brazilian hair in any weave technique you prefer, allowing you the freedom of choice. However, when a stylist states that she offers a Brazilian weave, she may also be referring to a technique known as the Brazilian knot, where the extension is bound to the hair in small sections using an elastic thread. Taking care of a Brazilian weave is similar to any other human hair weave, but there are a few minor considerations when taking care of Brazilian hair and the Brazilian knot in particular. For details welcome to visit our website
www.milkywayhairweft.com www.amazon.com/shops/MoonAngelHair
10/17/2022 11:22:12 AM •
Air Purifiers
Answered
on Oct 17, 2022
What is the best method for purifying water?
depends on where you are and when you want the water treated.
for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces )
if you want it for home use
running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs
for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best
so you need to specific as to when you want the water pure.
boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
