20 Most Recent
Soleus Air 25-pint Dehumidifier Questions & Answers
Where do I find a
Hi there
Most decent tool suppliers will sell you a kit of bits that are interchangeable with most battery drill/drivers.
Loads of manufacturers fit these raised center screws either hex or torx driver to reduce the number of people who can repair their equipment.
Regards
Gordon
No water in bucket after running 8 hours.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
I have a D70E A Soleus Dehumidifier that has begun making a rattling noise.
If it’s the one like move, vibration comes from the pump that takes reservoir water to be evaporated. Mine never seems to shut off and is noisy because there’s no water. And eventually it throws an e4 error saying that some water store is full. I can hear compressor come on nicely and quietly. I’ve cleaned the float switch area that was filthy. I was unable to easily remove and fully clean the inside of the donuts. Perhaps the funk is interfering with the float switch. Next step is to research these float switches for how they work. There in another float switch that is not connected anywhere, nor is there a place that it could connect to.
5/10/2020 6:51:11 PM •
Soleus...
Answered
on May 10, 2020
What does E5 mean on Soleus Air dehumidifier?
hi Randal.
this is all i could find on the internet.
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner
problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer.
you could try this link as well to see if its of any help to you.
What does E5 mean on Soleus Air dehumidifier Google Search
12/3/2017 5:22:27 PM •
Soleus...
Answered
on Dec 03, 2017
