20 Most Recent
Movado 800 Performance watch Questions & Answers
Movado stops when not worn
It is likely you need to take it to be repaired.
There is some small piece of metal or grease that clutches when the watch is in your wrist.
A good watch repair service will do the job.
Www.tictacarea.com
My watch stops in the night.But works fine when i
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
I have a Movado 800
That watch has a quartz movement and most likely needs a new battery. Take it to a jeweler or to Sears for the replacement. It only takes a few minutes and should coat about $10.
How do u you set
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point
