20 Most Recent Kodak EasyShare SV811 (8858946) Digital Picture Frame Questions & Answers
2answers
Current file is bad message keeps coming up. I have 130 photos,
I had this problem - The problem is the way that the file was encoded after editing in photoshop. When saving it as a JPEG you must make sure that the format options are set to either Baseline "standard" or Baseline "Optimized". If the format settings are set as Progressive you will get the error "current file is bad blah blah blah"
Hope this helps.
1/25/2021 5:59:39 PM • Kodak EasyShare... • Answered on Jan 25, 2021
2answers
How do i get my video to play....i am following
Make sure that you have the correct video format and compression. Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
You will need to re-edit the video files you have for the frame to recognize it.
9/26/2019 3:47:43 AM • Kodak EasyShare... • Answered on Sep 26, 2019
I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
1/20/2015 7:32:18 PM • Kodak EasyShare... • Answered on Jan 20, 2015
How do i find a picture of myself on youtube?
you will need to know the name that was given to that pic / video for you to find it. ask the people that saw it, if they don' t know, well good luck !! ps; they also may be pulling your leg and there really is no pic.
9/30/2014 8:58:56 PM • Kodak EasyShare... • Answered on Sep 30, 2014
Frtom i pod toch
Connect ipod to your computer and copy pictures to an sd card. Place card in photo frame
6/27/2014 9:11:03 PM • Kodak EasyShare... • Answered on Jun 27, 2014
2answers
Do not know how to transsfer pic fromcomputer to
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
4/20/2014 3:58:48 AM • Kodak EasyShare... • Answered on Apr 20, 2014
Where can I get the manual for the Kodak DPF 800
You may view/download the extended user guide here.
3/18/2013 3:27:14 AM • Kodak EasyShare... • Answered on Mar 18, 2013
How to load photos onto frame
transfer the image from PC to memory card ( JPEG Format) and then insert the card in the photo frame. Then turn on and play.
10/9/2012 6:32:43 PM • Kodak EasyShare... • Answered on Oct 09, 2012
I cannot tranfer pictures from sony dsc-w30 camera to my computer .camera screen always show usb mode connecting
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
4/18/2012 5:17:19 PM • Kodak EasyShare... • Answered on Apr 18, 2012
How to load pictures to
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
1/24/2011 2:01:23 AM • Kodak EasyShare... • Answered on Jan 24, 2011
How do you get pictures from computer to frame
I have same problem....help??
12/12/2010 6:03:56 PM • Kodak EasyShare... • Answered on Dec 12, 2010
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
110 questions posted
Top Kodak Photography Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Kodak Photography Expert? Answer questions, earn points and help others
View Most Popular
Kodak Photography
  • Kodak Photography
Most Popular Question
get manual kodak dpf 800
  • Photography
