20 Most Recent PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Questions & Answers
Need help importing from Tag Folder to internal Digital Frame dri
You could try 'import from camera', see if the frame accepts the folder on your PC as the memory of the camera.
6/14/2017 8:18:05 AM • PANDIGITAL PAN... • Answered on Jun 14, 2017
Pictures rotated will not stay and replay doesn't work
The frame will only show the pictures in the orientation in which they were loaded - you can change this in the frame, but it cannot save the changes. The only way to deal with it is to change the image orientation before downloading to the frame - this has to be done in image-processing software, and saved.
3/9/2017 11:34:04 AM • PANDIGITAL PAN... • Answered on Mar 09, 2017
3answers
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
1/23/2017 10:23:58 PM • PANDIGITAL PAN... • Answered on Jan 23, 2017
How do I delete pictures off the SD Card? I see the delete button on the remote, but I am unable to find a menu option to delete.
Better take it to your computer so you can more easily handle all the photo files at once.
12/10/2014 5:31:21 PM • PANDIGITAL PAN... • Answered on Dec 10, 2014
Reprogram from Factory Settings
To make it a reset, you have to enter its service mode option. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
11/29/2014 3:56:28 PM • PANDIGITAL PAN... • Answered on Nov 29, 2014
0answers
PI1056DW
Be the first to answer 6/21/2014 6:40:57 AM • PANDIGITAL PAN... • Posted on Jun 21, 2014Be the first to answer
How to remove battery digital picture frame
I believe the only battery you have to replace is in the Remote Control ? The picture frame itself does not have a battery .. only the A/C connection. To Install or Replace the Remote Control Battery : 1. Hold the Remote Control with the control buttons facing downward. 2. While pressing down on the ridged area of the battery cover, pull the tray out. 3. Place a "CR2025" Lithium battery on the tray with the positive "+" end facing toward you. 4. Close the tray. Hope this helps.
5/24/2014 3:04:07 PM • PANDIGITAL PAN... • Answered on May 24, 2014
How to replace the battery in the remote control: 1. Hold the remote control with the buttons facing down. 2. Push and hold the small release tab while pulling the battery tray out. 3. Replace the "CR2025" Lithium battery on the tray with the positive (+) side facing up. 4. Push the tray back in until it clicks into place. You can download the manual here: http://www.robholland.com/blog/wp-content/uploads/2011/01/User-Guide-for-Pandigital-PAN7000DW.pdf
5/3/2014 3:44:29 PM • PANDIGITAL PAN... • Answered on May 03, 2014
Pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
5/3/2014 12:04:40 PM • PANDIGITAL PAN... • Answered on May 03, 2014
0answers
2answers
I have just got a
I had a similar issue and found the solution at their website -
http://www.pandigital.net/support
It also had PDF files for all of their manuals so I didn't have to squint.
Sam
12/26/2011 8:15:55 PM • PANDIGITAL PAN... • Answered on Dec 26, 2011
PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Logo
73 questions posted
Top PANDIGITAL Photography Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
View Most Popular
  • PANDIGITAL Photography
Most Popular Question
need replace
  • Photography
