20 Most Recent
ASUS P5LD2-X/1333 - motherboard - ATX - i945GC Questions & Answers
Need to update bios on my sony pcvrx770
Get onlineand got to www.google.com In the google search box type: "SonySupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Bios drivers.
5/15/2012 4:52:10 AM •
ASUS...
Answered
on May 15, 2012
Cmos bios bad asus p5ld2-x/1333
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment. The ASUS Update utility allows you to: · Save the current BIOS file · Download the latest BIOS file from the Internet · Update the BIOS from an updated BIOS file · Update the BIOS directly from the Internet, and · View the BIOS version information. You need an Asus motherboard in your system. Rules for Safe BIOS update: 1. For safety reasons, always use the most updated BIOS utility! 2. Do not overclock the system/CPU during BIOS update! 3. Load "Setup Default" in BIOS menu before BIOS Update. 4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP). 5. Close all application programs under Windows. 6. Disable any existing Anti-Virus applications in the system. 7. Reboot the PC after the BIOS update is complete. 8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
5/23/2011 7:01:40 AM •
ASUS...
Answered
on May 23, 2011
Asus psgc.mx/1333 audio supporte free
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
10/27/2010 3:44:20 AM •
ASUS...
Answered
on Oct 27, 2010
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
