20 Most Recent 2004 Ford F150 Questions & Answers
2answers
What is the torque for
The axle nut torque is:
296 ft-lbs for 2WD
and
20 ft-lbs for 4WD
Make sure you use the correct torque for your application!
10/27/2023 5:48:30 PM • 2004 Ford F150 • Answered on Oct 27, 2023
2002 Ford F-150 FX4 automatic. Can I add pics of what I think is a Crack in the transfer case of my truck?
Yes, just click the button below that says 'Photos' below and follow the instructions to where you have the image stored. F-150 crack right here :>D .. download-undefined-undefined-0_9.jpg
9/14/2023 11:58:38 PM • 2004 Ford F150 • Answered on Sep 14, 2023
2answers
Where can I find the entry code for the door key pad for a 2004 F-150?
Either in the glove box or sometimes they put it under the hood. Also check the back wall under the carpet panel
4/7/2023 12:58:03 AM • 2004 Ford F150 • Answered on Apr 07, 2023
2answers
My fog lights are not
I have a 2004 f150 xlt triton. I couldn't figure out the how to turn on the fog lamps and the manual was not helpful.Solution: turn the light switch all the way to the right and pull the switch (out) towards you. Push switch in and it turns off. The manual says to turn switch all the way to right but doesn't say to pull switch out.
3/15/2023 10:30:52 PM • 2004 Ford F150 • Answered on Mar 15, 2023
2answers
Which fuse is for the tail lights
The tail lights are on a 15amp fuse marked F2-17.The location should be in your owners manual.
12/23/2022 8:56:19 PM • 2004 Ford F150 • Answered on Dec 23, 2022
I can not find the ECT on my 2004 ford F150 truck
Hi, I assume your getting a PO 119 code: "The PCM has determined that the input from the engine coolant temperature sensor is intermittent"? The CHT sensor is in the valley of the motor under the intake manifold. If you’re looking at the motor from the front, it's on the rear passenger side. To change it, you need to remove the intake manifold. If you have small hands and flexible wrists, you can get a 3/4 wrench around it and remove it. This is about a three hour job at the dealer.
12/3/2022 7:27:07 PM • 2004 Ford F150 • Answered on Dec 03, 2022
Starter solenoid kicks back before engine starts
it may push the gear out just fine, but lack power to keep it pressed forward .Sounds like a solinoid problem. It is turning off before releasing the key. Check the solinoid! God-Bless!
12/1/2022 10:31:58 PM • 2004 Ford F150 • Answered on Dec 01, 2022
2answers
Ford vacuum diagrams
Without more detail it is hard to say which diagram you need but if you copy and paste this into google.com's search field then select the word images directly underneath where you pasted it, you will see many options. Copy and paste this; 2004 Ford F150 Ford vacuum diagrams Or, I have added a link here that has a view of the top of the motor with vacuum lines marked. vacuum lines on intake manifold Ford F150 Forum Community of Ford Truck...
10/29/2022 9:39:26 AM • 2004 Ford F150 • Answered on Oct 29, 2022
I have a 2004 Ford F150 5.4 Tritan. I have had 5 broken flywheels in the last 6 months. Im about to take her out back and beat her with a bat.
5 Flywheels? Where EXACTLY are they breaking? This will give clues as to what the issue is. Have you used a Dial Indicator to check the 'run out' on the flywheel and the crank flange? This is a measurement to see if the crank is spinning the flywheel without any wobble which could be signs of issues with crank seals, big end bearings and/or the crank itself. Use the comment button below with more information and I'll try to help you more.
10/13/2022 8:58:59 PM • 2004 Ford F150 • Answered on Oct 13, 2022
Location of computor module for keypad entry
the keyless entry module is on the drivers side of the truck up under the dash directly above the emergency brake. The tag should have a 5 digit number in bold, that is your door code.
10/5/2022 11:24:35 PM • 2004 Ford F150 • Answered on Oct 05, 2022
2answers
How do I replace the cigarette lighter housing?
The cigar lighter is installed from the back of the center trim panel.
To remove the center trim panel, open the ash tray and pull out on each lower corner. It will be hard the 1st time you remove the spring clips. Once the lower part is released, work your way up to the top, there are 3 spring clips on each side of the center trim panel. ( circled in black in the picture below )
When you get to the top, be careful how far out you pull, the Passenger airbag deactivation light is at the top, with 2 small wires to it. ( circled in green )
Once you have the center panel released, you can remove the HVAC connector ( clamp over type connectors ) or work on it in the truck.
Remove the cigar lighter connector, and release the locking tabs on the cigar lighter body. Pull the lighter plug through the front of the panel.
3/9/2022 11:16:23 PM • 2004 Ford F150 • Answered on Mar 09, 2022
2answers
No power in 7.5 fuse for plow joystick
1/14/2022 5:06:18 AM • 2004 Ford F150 • Answered on Jan 14, 2022
2answers
I think i marked the
Check this diagrams...
2004 Ford F 150 Heritage 4.2 liter V-6 VIN "2"
4.2L Engine Firing Order: 1-4-2-5-3-6 Distributorless ignition system
Hope helps.
11/10/2021 6:20:55 AM • 2004 Ford F150 • Answered on Nov 10, 2021
How do I do a factory reset on a 2004 Ford F-150?
To do a hard reset on the vehicle disconnect both battery terminals and touch them together without touching the battery for 60 seconds. But it sounds like you may have failing coils.
11/4/2021 8:08:53 AM • 2004 Ford F150 • Answered on Nov 04, 2021
Where is fuel shut off reset at
Passenger side foot well, find fuse box, look up and toward the engine compartment. Its a small black part with a red or white plunger on top. It can be hard to see, it requires some contorting but easy to feel for.
10/27/2021 9:25:56 PM • 2004 Ford F150 • Answered on Oct 27, 2021
Q problema es el codigo
have a 2004 ford f150 with a 5.4L. While the truck would sit and idle my temp gauge would go to zero and the check gauge and check engine light would come on. Ran the codes and got P1289. Cleared the codes and truck would do fine for a few days and then it would happen again while sitting and idling. I replaced the CHT sensor and cranked the truck. The check gauge light can on and got the P1289 code. Replaced the CHT again(thinking the new one was bad) and cleared the codes. Cranked the truck again and it did the same thing. Cleared the codes and the check gauge light and check engine light would come back on with the motor running. When the motor is warmed up, I turned on the key on without cranking the motor, the temp gauge works, when the motor is cranked and running, the temp gauge goes to zero and the the ckeck gauge light on back on and gives the P1289 code. Does any one have any ideas on what to do
7/13/2021 11:37:11 AM • 2004 Ford F150 • Answered on Jul 13, 2021
3answers
Why do spark plugs keep getting destroyed?
I'd suspect a probem with timing. An engine running with the timing off can run very hot from pre-ignition. Overheating can cause plugs to fail prematurely.
12/9/2020 12:10:09 AM • 2004 Ford F150 • Answered on Dec 09, 2020
2answers
Where is a shift solenoid located on a ford f150
They are in the transmission . Remove the transmission fluid pan. You will see the valve body , the solenoids are mounted to it. They are clipped in. Do not remove the valve body unless you have to. Things pop out of it. Be careful removing solenoids, things can pop out of these holes also. Hold the solenoid and remove the clip/s.
1/14/2020 7:40:59 AM • 2004 Ford F150 • Answered on Jan 14, 2020
2answers
2004 Ford F-150 horn not working
test steering wheel switch for failure
7/4/2019 7:32:57 PM • 2004 Ford F150 • Answered on Jul 04, 2019
2004 Ford F150 Logo
4,114 questions posted
Popular Products
1990 Ford F150
1990 Ford F150
1,214 Questions
2005 Ford F-150
2005 Ford F-150
1,298 Questions
2006 Ford F-150
2006 Ford F-150
1,038 Questions
1991 Ford F150
1991 Ford F150
974 Questions
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
View Most Popular
F-150 Ford
  • F-150 Ford
Most Popular Question
2004 f150 cruise control will not set or
  • Cars & Trucks
