20 Most Recent 2000 Dodge Durango Questions & Answers
My 2000 Durango has no rad fan relay or trans relay or 02 #2 relay is that a bad thing or what are they even for? Also my truck shuts off when I press on gas at stop sign them won't turn on .
Are you sure? I do not see a O2 relay on my 2000 Durango 4X4 SLT but I know I have a rad fan relay as well as ( actually I will need to see for sure if I have a Tranny Relay or not, I know this post is a bit old but may help someone now that has similar issues. As far as dies when you gas it at a stop sign then will not start again?? could you elaborate as this is way to Vague to allow me to have any decent info to tell you and I hate it when people answer and seem to have only read 2 words out of a 100 word paragraph. Like asking where the fuel filter is located and how to properly and safely replace it and someone says Mechanic or goes on talking about the octane and fuel cap and nothing remotely about the OP ?? other then maybe the WORD Fuel.
11/19/2023 2:17:06 AM • 2000 Dodge... • Answered on Nov 19, 2023
2answers
2000 Dodge Durango. WHAT DO I DO WHEN THE MECHANIC IS WRONG?
The tie rod ends should have a taper to them and likewise, the knuckle will have a taper to the hole the tie rod end goes into. As long as the tapers match, you are good. As far as driving without an alignment, if it feels secure when you drive, I wouldn't worry about it. You might get excess tire wear, but if you are only driving for a few days until the parts are in, you should be fine.
9/13/2023 6:27:56 PM • 2000 Dodge... • Answered on Sep 13, 2023
2000 Dodge Durango. Wiring colors for installation of a 7 round trailer plug please?
Round 7-Pin Wiring Diagram
  • ? White Ground.
  • • Brown Taillights.
  • • Green Right turn / brakes.
  • • Red Auxiliary power.
  • • Yellow Left turn / brakes.
  • • Black Reverse lights.
  • • Blue Electric brakes.
Trailer Wiring Diagram and Installation Help - Towing 101
12/30/2022 4:55:52 AM • 2000 Dodge... • Answered on Dec 30, 2022
2answers
Need diagram for firing order to a 2000 Dodge
I apologize for the late response...Due to the bad economic situation this site has had a substantial (+50%) increase in the number of questions being asked in the last four months.
For the 4.7L:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
8----------7
6----------5
4----------3
2----------1
(Front of Vehicle)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
12/23/2022 8:56:51 PM • 2000 Dodge... • Answered on Dec 23, 2022
3answers
2000 Dodge durango wont start after driving for a while.
i had the same problem in a dodge ram pick up. ended up being the coil. when the coil got hot my truck would die or not start again until the engine had cooled down. replaced the coil, and whalaaaaah. no more trouble. good luck!!!!!!!!!!!!!!
10/10/2022 8:20:13 PM • 2000 Dodge... • Answered on Oct 10, 2022
2answers
2000 dodge durango cooling issue: I HAVE THE 5.2L
Ihave a 2000 Dodge Durango i have put a new radiator and the gaskets came back good um i replaced the coolen fan also the thermostate and tested it it it came back good when i run it its fine but when i am in line its hot when i drive it cools down........
8/5/2022 1:04:20 AM • 2000 Dodge... • Answered on Aug 05, 2022
2answers
Why after I took my four wheel drive out the front wobbles? sometime and over 55 mph its making a loud humming sound?
For the wobbling. Can you feel the wobbling in the steering wheel? If so. 1 Check tires for knots or steel breaks, 2 bent rims. 3 Check lug nuts, Also check oil-grease in front end. Humming could very well be dry front end or bearing.
4/16/2022 9:25:46 PM • 2000 Dodge... • Answered on Apr 16, 2022
Locate pressure regulator
google Dodge 2000 Durango fuel pressure regulator location for more info
3/1/2022 11:45:00 PM • 2000 Dodge... • Answered on Mar 01, 2022
Bad gas mileage, black smoke,hesitating
tune up
3/1/2022 11:44:40 PM • 2000 Dodge... • Answered on Mar 01, 2022
2000 Dodge Durango 4x4 with 4.7 L I have the engine light on and airbag light on and it's running rough but can be the issue
You need to go to autozone and they will gladly give you an error light meaning. Ypu may know that a little thing can give those lights on your Dodge.Good Luck!
1/8/2021 9:42:26 PM • 2000 Dodge... • Answered on Jan 08, 2021
2answers
Making a clicking/grindind sound from left front side under power forward only
If it is a front wheel drive more then likely your wheel bearing is going out. Have it looked at not a hard job to do.
12/23/2019 8:20:08 PM • 2000 Dodge... • Answered on Dec 23, 2019
2answers
2000 dodge durango no headlights all other lights
The diagram is for headlamps, The top wire to headlamps in diagram is voltage, fuse protected and hot all the time. On/off--hi/lo beams are controlled on the headlamp ground circuit, bottom wire coming from headlamps in diagram. The dimmer and headlamp switch are part of the headlamp ground circuit. headlamps-x4azhumg2c4vrdfu4oq5lt4e-3-0.jpg
4/6/2019 3:28:02 PM • 2000 Dodge... • Answered on Apr 06, 2019
Replacing fan shroud in 2000 durango 5.2l
3/23/2019 3:31:43 AM • 2000 Dodge... • Answered on Mar 23, 2019
2000 dodge durango will ot shift into park
hello u'd need a proper manual for this in my opinion like there are plenty of dealers and online shops that deal in those.. you can get some free at reliable-st ore and it;s actually really illustrative
2/19/2019 9:04:04 AM • 2000 Dodge... • Answered on Feb 19, 2019
2answers
2000 Durango and the delay on the wipers and the automatic door locks stopped working at the same time also the interior lights don't come on when I open the door but do if I manuaully turn them on
Could be a problem with the central timer module or a battery voltage supply or ground circuit . Do you know anything about automotive electronics ,control modules ? Do you know how to read an use a wiring diagram along with a DVOM - digital volt ohmmeter to test an electrical circuit ? You probably don't have a professional scan tool that can read DTC'S - diagnostic trouble codes from the CTM . If it has the ability to store these type codes . Free wiring diagrams here http://www.bbbind.com/free-tsb/ Enter vehicle info. year , make , model an engine . Under system click on body & accessories , then under subsystem click on power locks or wipers ,which ever doesn't matter . Click the search button then the blue link. Looking at the diagrams you will see the central timer module is involved in all the diagrams . The lock switches are inputs to the CTM , the CTM locks or unlocks the doors . https://www.youtube.com/watch?v=_nhlqRGNHzo&t=376s https://www.youtube.com/watch?v=SO-eKuhCOqc&t=125s
1/31/2019 11:03:38 PM • 2000 Dodge... • Answered on Jan 31, 2019
19answers
My 2000 Durango suddenly starts running rough.
First, check the injector connector for tightness and corrosion. Then check computer connectors and any in-between connectors. Take the car to one of the auto parts stores that have the free code-reader service. look for set codes, delete them and run the engine too see if the code comes back. If it does not, one at a time jiggle the injector connectors to see if one sets a code, likewise any other plugs you can reach, fuses and relays. If the store clerk does not want to go through this routine, buy a code reader, preferably one with the re-set feature. Many cars require you to drive 15 or so miles after clearing the codes before new ones can set. Good reason to have your own. It may take a few years for the code reader to pay for itself, but you'll probably be driving for a few years.Or, go back to a parts store after driving far enough to set new codes, if any. Or spend bucks while repair shops change parts until the problem is corrected. I keep a code reader in my van since 1997, have not needed it yet with my 2009 g-caravan.
1/27/2019 6:16:27 PM • 2000 Dodge... • Answered on Jan 27, 2019
7answers
My 2000 dodge durango turn signal lights stop working.
A Mechanic told me my switch was broken, but the switch was working fine, the lights just stopped flashing. After some research and consulting with a male friend who knows more about this than I, we discovered it was only the turn signal flasher -- a $16.00 part. On the 2000 model, it's located under the dash, on a separate fuse panel I didn't even know was there. It's to the left of the steering column and right behind the main fuse box, but you can only get to it by going up under the dash. The green one is a little hard to get to, but that's the one for the hazard lights. Its easy to see with a good shop light. It's 1" by 1" ish. The turn signal flasher is below the green one. It's black and a little smaller, and much easier to get to. You simply unplug it and plug the new one in. Voila! There are other fuses on this panel -- I'm not sure what they go to, but I intend to find out so I don't waste money replacing parts I don't need to.
10/12/2018 2:49:16 AM • 2000 Dodge... • Answered on Oct 12, 2018
2000 Dodge Durango Logo
2,438 questions posted
Popular Products
1999 Dodge Durango
1999 Dodge Durango
2,049 Questions
2001 Dodge Durango
2001 Dodge Durango
1,378 Questions
2002 Dodge Durango
2002 Dodge Durango
886 Questions
2004 Dodge Durango
2004 Dodge Durango
1,005 Questions
2003 Dodge Durango
2003 Dodge Durango
766 Questions
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
View Most Popular
Durango Dodge
  • Durango Dodge
Most Popular Question
when mechanic wrong
  • Cars & Trucks
